FSiglmueller
Applications don‘t get installed during Build and Capture
ok i need to see more of this task sequence, please include a screenshot of the entire ts, are the install software update steps happening before or after the install applications ? because the last thing in your latest log is
  Quote
Successfully completed the action (Restart Computer - Software Updates 1) with the exit win32 code 0
Expand
  On 12/28/2020 at 1:38 PM, anyweb said:
so you disabled all software update steps and it still fails ? please included the logs from that test.
Expand
Yes, I disabled the Softwareupdate Step in Front of the application Install. The Result is the Same like before (it fails)
I will Upload the Logs later.
attached are the logs.
When I check the ccmsetup.log I says, that the name of the certificate does not contain the name of the capturing system.
Have you got the chance to check my last post ?
Have you got an idea, where my mistake is for the certificate ?
If you have a manual for me I would appreciate it.
Thanks in advance.
Logfiles.zipFetching info...
