Hasnat
SCCM 2007 OSD Issue with Cisco Catalyst 6509 DHCP across Vlans
I have SCCM 2007 Server, which is under VLAN15, i am using Catalyst 6509E as my DHCP with several VLANs. i have tested by creating a test dhcp pool range within same VLAN where my SCCM 2007 server resides, OSD (operating system deployment) deployment is successful without any errors. Across the VLANs i get errors while OSD deployment. under test DHCP pool i have added option 66, 67 plus i have also tried ip helper address under vlan interface but didnt help. Find my configuration for Servers VLAN and Client VLAN below.
By Client computer BIOS option are to boot from NIC.
Servers VLAN
interface Vlan15
description SERVERS
ip address 172.20.15.1 255.255.255.0
Client VLAN
interface Vlan30
ip address 172.30.10.20 255.255.255.0
ip helper-address 172.20.15.34
Note: 172.20.15.34 is my SCCM 2007 Server, i have also tried 172.20.15.1 as ip helper didnt help as well
Client DHCP Excluded Range
ip dhcp excluded-address 172.30.10.20 172.30.10.50
Client DHCP Pool
ip dhcp pool sccm
network 172.30.10.0 255.255.255.0
bootfile pxeboot
default-router 172.30.10.20
domain-name aou.edu.kw
dns-server 172.20.15.31 172.20.15.30
option 66 ip 172.20.15.34
option 150 ip 172.20.15.34
option 43 ip 172.20.15.34
option 67 ip 172.20.15.34
Note: 172.20.15.34 is SCCM 2007 Server
Errors:
If i remove ip helper from interface VLAN of client, Client takes IP address across VLAN but dont start OS deployment. i recieve below error.
PXE-E32: TFTP Open Timeout
If i provide ip helper address (SCCM 2007 Server ip address 172.20.15.34) under client VLAN i recieve below error.
PXE-T04: Access Violation
PXE-E36: Error Recieved from TFTP Server
PXE-M0F: Exiting Intel Boot Agent
3 answers to this question
How can i check the pxe logs. can you kindly send me some links for checking pxe logs.
I have made a double check, boundaries are also added there. i have issue for deploying OSD across VLANs. under same VLAN OS deployment is fine.
