Kingskawn
IPU is not working on some machines
I've got the weirdest thing on some machines (200). These were the first bare-metals on 1803 we did, and now we want them to upgrade to 1909. When launching the IPU TS it runs like 8 seconds and the status goes to failed and quickly (like 50ms) it changes to available again.
I monitored the CCM\logs and "C:\$Windows.~BT\Sources\panther" folders but there's no change at all.
@niall always says that logs are the answer, but I don't even know where to look for them ?
  On 1/29/2021 at 7:32 PM, anyweb said:
what does the smsts.log tell you ?
Expand
I put the machine in the debug state to see if I can get more info. (TSDebugMode=True) This is the log for now (waiting for debugger)
We're on CB 2006. Waiting to upgrade to 2010
smsts.logFetching info...
ah is there a child task sequence involved ?
Run Task Sequence step is disabled. Not including child task sequence with package ID 'PRI004CA' into the sequence.
The child TS is not disabled on itself but I disabled the step in the main TS
Expand
