Sturag
Software Metering on Visio PRO and Visio Std
Hi
How can SCCM Software Metering know the difference between Vision Standard and Visio Pro?
If i put up a rule to meter Visio Standard, the exe file and version is exactly the same for the PRO exe file.
I like to meter both of the applications...
SCCM 2007 R2
2 answers to this question
winproj.exe is the same exe name for both standard and professional, so for software metering it is hard to distinguish which is which. The best way from a licensing point of view is to setup asset intellingence, which I have documented: http://www.windows-n...-up/#entry21586
Next run the following- Report Name: License 14A - Microsoft Volume Licensing Reconciliation Report
From here you will be able to seperate visio std and pro and total installation count and the option to expand it to show each device
