sajeret
ADR for Adobe Reader DC / DC Continuous Track
I tried to set an ADR rule for Adobe Reader DC. The rule has the following settings. If I run the rule, the following will appear in the ruleengine.log.
  Create Deployment Rule Action XML is: <DeploymentCreationActionXML xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><DeploymentId>{e509394c-0e39-429a-b38e-f06b7b9d900f}</DeploymentId><DeploymentNumber>0</DeploymentNumber><CollectionId>PS100014</CollectionId><IncludeSub>true</IncludeSub><Utc>false</Utc><Duration>0</Duration><DurationUnits>Hours</DurationUnits><AvailableDeltaDuration>0</AvailableDeltaDuration><AvailableDeltaDurationUnits>Hours</AvailableDeltaDurationUnits><SoftDeadlineEnabled>false</SoftDeadlineEnabled><SuppressServers>Checked</SuppressServers><SuppressWorkstations>Unchecked</SuppressWorkstations><PersistOnWriteFilterDevices>Checked</PersistOnWriteFilterDevices><RequirePostRebootFullScan>Unchecked</RequirePostRebootFullScan><AllowRestart>false</AllowRestart><DisableMomAlert>false</DisableMomAlert><GenerateMomAlert>false</GenerateMomAlert><UseRemoteDP>false</UseRemoteDP><UseUnprotectedDP>false</UseUnprotectedDP><UseBranchCache>true</UseBranchCache><EnableDeployment>true</EnableDeployment><EnableWakeOnLan>false</EnableWakeOnLan><AllowDownloadOutSW>false</AllowDownloadOutSW><AllowInstallOutSW>false</AllowInstallOutSW><EnableAlert>true</EnableAlert><AlertThresholdPercentage>90</AlertThresholdPercentage><AlertDuration>7</AlertDuration><AlertDurationUnits>Days</AlertDurationUnits><EnableNAPEnforcement>false</EnableNAPEnforcement><UserNotificationOption>HideAll</UserNotificationOption><LimitStateMessageVerbosity>true</LimitStateMessageVerbosity><StateMessageVerbosity>1</StateMessageVerbosity><AllowWUMU>true</AllowWUMU><AllowUseMeteredNetwork>false</AllowUseMeteredNetwork></DeploymentCreationActionXML>    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
  Rule XML is: <AutoDeploymentRule xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><DeploymentId/><DeploymentName>Monthly Updates Adobe Reader DC</DeploymentName><DeploymentDescription>DC Continuous Track</DeploymentDescription><UpdateGroupId>ScopeId_06767197-8CBF-4EAF-964D-EEFAA055FEE2/AuthList_69f547e1-d58e-4291-b5c3-61dc60a7fd33</UpdateGroupId><LocaleId>1033</LocaleId><UseSameDeployment>false</UseSameDeployment><EnableAfterCreate>true</EnableAfterCreate><NoEULAUpdates>false</NoEULAUpdates><AlignWithSyncSchedule>false</AlignWithSyncSchedule><ScopeIDs><ScopeID>SMS00UNA</ScopeID></ScopeIDs><EnableFailureAlert>true</EnableFailureAlert><IsServicingPlan>false</IsServicingPlan></AutoDeploymentRule>    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
  Criteria Filter Result XML is: <AutoDeploymentRule xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><DeploymentId/><DeploymentName>Monthly Updates Adobe Reader DC</DeploymentName><DeploymentDescription>DC Continuous Track</DeploymentDescription><UpdateGroupId>ScopeId_06767197-8CBF-4EAF-964D-EEFAA055FEE2/AuthList_69f547e1-d58e-4291-b5c3-61dc60a7fd33</UpdateGroupId><LocaleId>1033</LocaleId><UseSameDeployment>false</UseSameDeployment><EnableAfterCreate>true</EnableAfterCreate><NoEULAUpdates>false</NoEULAUpdates><AlignWithSyncSchedule>false</AlignWithSyncSchedule><ScopeIDs><ScopeID>SMS00UNA</ScopeID></ScopeIDs><EnableFailureAlert>true</EnableFailureAlert><IsServicingPlan>false</IsServicingPlan></AutoDeploymentRule>    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
    Parsing Deployment Action XML...    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
    Parsing Rule XML...    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
Could not find element UpdateGroupName    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
Could not find element IsOldUpdateGroupCurrent    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
Invalid boolean value    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
The rule resulted in no updates being found. Skip deployment creation or update...    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
CRuleHandler: Rule 4 Successfully Applied!    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
CRuleHandler: ResetRulesAndCleanUp()    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
Rule result is: 1    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
CRuleHandler::CreateFailureAlert - Alert ID = 16777241    SMS_RULE_ENGINE    11.06.2021 13:26:37    7860 (0x1EB4)
Rule settings:
