ksama1
I need help with a few things
I am trying to use MDT to deploy windows 7. The machine I have mdt on is a windows 7 machine. My issue is that I cant get the updates to apply during the deployment. It gets to the installing updates part but then it crashes out and says windows could not apply unattend setting [offlineservicing]. I have narrowed it down to it being the updates because if I use a virgin copy of windows 7 to install using the drivers and answer file and such it works fine, but if I use updates it doesnt allow it to go past that step. I been looking to configure the mdt 2010 alot more but the options seem limited. It might be that I dont know how to enable this on a windows 7 machine.
0 answers to this question
