adelgehier Posted December 6, 2021 Report post Posted December 6, 2021 Hello, I am currently trying to update workstations with SCCM to go from Windows 10 1903 to Windows 10 21h1. The problem is that once the update is pushed on the desired clients, on the client no update is available in the software center. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted December 6, 2021 Report post Posted December 6, 2021 are you pushing a task sequence or some other method, more details would be useful Quote Share this post Link to post Share on other sites More sharing options...
adelgehier Posted December 6, 2021 Report post Posted December 6, 2021 24 minutes ago, anyweb said: poussez-vous une séquence de tâches ou une autre méthode, plus de détails seraient utiles My english is not very correct. To update I go to Windows 10 Maintenance >> I search for my update in the list then right click deploy and I deploy on a group that contains all my customers who need to update. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted December 6, 2021 Report post Posted December 6, 2021 ok have you also deployed a Servicing Stack Update to those devices ? Download the SSU from: https://www.catalog.update.microsoft.com/Search.aspx?q=KB5005260 Quote Share this post Link to post Share on other sites More sharing options...
adelgehier Posted December 6, 2021 Report post Posted December 6, 2021 Yes everything is good on some post it works I think the post I'm trying to update appears as unknown and I can't figure out why. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted December 6, 2021 Report post Posted December 6, 2021 are there any differences on the clients that work, versus those that fail, for example are their language packs installed ? Quote Share this post Link to post Share on other sites More sharing options...
adelgehier Posted December 7, 2021 Report post Posted December 7, 2021 12 hours ago, anyweb said: are there any differences on the clients that work, versus those that fail, for example are their language packs installed ? Not all customers are identical are identical pc using a master Quote Share this post Link to post Share on other sites More sharing options...
