zhangyongcheng
MECM 2203 task sequence problem
normally you should always have both the X64 and X86 versions of the boot image on your PXE enabled Distribution Point.
you can also check the source version, you can add that column to your SCCM view,
for package RPI00002:3, RPI00002 is the packageID, 3 is the source version,
you need to confirm that the source version 3 is indeed on the dp's mentioned in the log
I Googled the solution for two days. But there is no effective solution to the problem.
I was wondering if there was something wrong with my base environment.
MECM2203 version:
Will there be any special attention to deployment
1)Three DP Server 2019
2)One AD domain controller;A SQL server;The distribution point and the administration point are one DP
3)ADK&winPE  The following
did you verify that the source version 3 of the package is on your dp(s) ?
did you distribute BOTH the x86 and x64 boot images to your dp(s) ?
if not, please do that before assuming something is wrong with your site, let's rule out one thing at a time,
niall
