Lancaster41
WDS and two deployments simultaneously problem computername
Hello, if there are 2 technicians doing a deployment Windows 10 simultaneously with Windows Deployment Services (WDS) and they use the same computername to join Domain. How can WDS detect that this name is already in use, when they are working at the same time and and they plan to use the same name?
Thanks.
2 answers to this question
the chances of two computers with the same name joining the domain at exactly the same time are slim surely, have you had problems with this or ?
If we have had a recent problem with 2 machines having the same name, because the technicians used (unintentionally and unknowingly) the same computername.  The WDS did not detect that failure, by deploying it at exactly the same time.  That is why it would occur to me if it is possible to query the WDS before one of the technicians performs a deployment, if it detects that the WDS is in use (in deployment phase) not being able to use it, I do not know how to do this, but it would be a control way to avoid that the same name be used when deploying multiple machines simultaneously.  Thank you for help.
