anyweb Posted July 16, 2010 Report post Posted July 16, 2010 This guide is for a beta product, namely vNext Beta 1. You might be wondering why I'm installing it from scratch and not using the VHD provided by Microsoft, the reason why is because I want to experience everything that is required to get vNext running in my Lab from installation, configuration and management. If you follow my steps you too will have a working vNext LAB. This is Part 1 of a vNext series in which I'll cover installation, configuration, usage and more of vNext. Get your Lab Ready. My vNext Lab is hosted in a brand new HyperV environment hosted on Server 2008 R2, I'm currently using a laptop with 4gb ram (yes I want more...), 325 GB hdd. There are two servers used in this Lab, AD1 (AD1 -active directory, dns, dhcp) and vNext (joined to our AD1 domain). I chose to install Windows Server 2008 R2 standard as the server OS for vNext. Once done I joined it to my newly created domain (2k8r2), verified DNS was working correctly via nslookup and was ready to begin the steps below. Create AD users: In addition I created some accounts in AD, namely: SMSadmin, a domain user, Testuser, a domain user, DomJoin, a domain user,(for joining to the domain) ReportsUser, a domain user for reporting services. ClientInstall, a domain admin user for installing the Vnext Client. Create Local Administrator accounts: On the vNext server I added the vNext site server computer account (vnext$) as a member of the Local Administrators Group. In addition, add the SMSadmin user to the Local Administrators group. Step 1. Download and uncompress vNext You can Download it from Microsoft Connect here or indeed download vNext beta 1 from here. Once downloaded, double click on the ConfigMgr_vNext_Beta_ENU_7469.exe file to uncompress it. Perform the following on the Active Directory Domain Controller as a Domain Administrator Step 2. Create The System ManageMent Container Open ADSI Edit, click on Action, Connect To and click Ok Double Click on Default Naming Contextand the DC= that appears below it Click on the + and scroll down to CN=System. Right Click on CN=System and choose New, Object Choose Container from the options, click Next and enter System Management as the value. Click Next and Finish. Press F5 to refresh ADSI Edit and you should now see the new System Management Container. Close ADSI Edit. Step 3. Delegate Permission to the System Management Container. Open Active Directory Users and Computers. Click on view, select Advanced Features. Select the System Management Container, and right click it, choose Delegate Control. When the Welcome to Delegation of Control Wizard appears click next, then click Add. click on Object Types, select Computers. Type in your vNext server name and click on Check Names, it should resolve. Click Ok, then Next. Choose Create a Custom Task to Delegate. click next, make sure This folder, existing objects in this folder and creation of new objects in this folder is selected click next, select the 3 permissions General, Property-Specific and Creation-deletion of specific child objects are selected then place a check mark in FULL CONTROL, and click next then Finish. Failure to do the above will mean that the System Management Container in AD will NOT POPULATE with vNext specific info and you will see many errors in your site status. Step 4. Extend the Active Directory schema for Configuration Manager Browse to where you uncompressed vNext and find \SMSSetup\Bin\x64\Extadsch.exe double click on Extadsch.exe. A command prompt window will appear briefly as the schema is extended, check in c:\ for a log file called ExtADSch.log it should look similar to this Quote <09-02-2010 06:42:11> Modifying Active Directory Schema - with SMS extensions. <09-02-2010 06:42:11> DS Root:CN=Schema,CN=Configuration,DC=2k8r2,DC=lab,DC=local <09-02-2010 06:42:14> Defined attribute cn=MS-SMS-Site-Code. <09-02-2010 06:42:15> Defined attribute cn=mS-SMS-Assignment-Site-Code. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-Site-Boundaries. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-Roaming-Boundaries. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-Default-MP. <09-02-2010 06:42:15> Defined attribute cn=mS-SMS-Device-Management-Point. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-MP-Name. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-MP-Address. <09-02-2010 06:42:15> Defined attribute cn=mS-SMS-Health-State. <09-02-2010 06:42:15> Defined attribute cn=mS-SMS-Source-Forest. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-Ranged-IP-Low. <09-02-2010 06:42:15> Defined attribute cn=MS-SMS-Ranged-IP-High. <09-02-2010 06:42:15> Defined attribute cn=mS-SMS-Version. <09-02-2010 06:42:15> Defined attribute cn=mS-SMS-Capabilities. <09-02-2010 06:42:19> Defined class cn=MS-SMS-Management-Point. <09-02-2010 06:42:20> Defined class cn=MS-SMS-Server-Locator-Point. <09-02-2010 06:42:21> Defined class cn=MS-SMS-Site. <09-02-2010 06:42:21> Defined class cn=MS-SMS-Roaming-Boundary-Range. <09-02-2010 06:42:22> Successfully extended the Active Directory schema. <09-02-2010 06:42:22> Please refer to the SMS documentation for instructions on the manual <09-02-2010 06:42:22> configuration of access rights in active directory which may still <09-02-2010 06:42:22> need to be performed. (Although the AD schema has now be extended, <09-02-2010 06:42:22> AD must be configured to allow each SMS Site security rights to <09-02-2010 06:42:22> publish in each of their domains.) Perform the following on the vNext server as SMSadmin Step 1. Install .NET 3.5.1 and WCF Activation In Server Manager select Features, Add Features, Select .NET Framework 3.5.1, also select WCF Activation and when prompted answer Add Required Features then select Next and Install Step 2. Download and install .net4 Download .net 4 from here. Double click the file. click on Install when the wizard appears. After a while it will complete, Click Finish when done click on Restart Now Step 3. Install SQL Server 2008 Start installing SQL Server 2008 as per this guide, however you may be prompted about upgrading it to SP1 later, ignore the warnings as we will install SQL 2008 sp1 after this. I chose to Install SQL server 2008 to D:\Program Files... Once SQL Server 2008 is installed, click on close Step 4. Upgrade SQL Server 2008 to SP1 CU6 Locate your update files and run it en_sql_server_2008_sp1_x64 then once upgraded reboot After the reboot, install the Cumulative Update 6 (CU6) Step 5. Install the remaining vNext Pre-requisites We need to install IIS, BITS, Remote differential compression so please startup Server Manager and select Features. Select the following Features: * Remote Differential Compression * BackGround Intelligent Transfer Service (BITS) Note that when you select BITS it will prompt you to install IIS dependancies, choose Add Required Role Services click next when ready click next at the IIS Introduction and verify the following IIS components are installed in addition to the ones preselected by the wizard. Common HTTP Features Static Content Default Document Directory Browsing HTTP Errors HTTP Redirection Application Development ASP.NET .NET Extensibility ASP ISAPI Extensions ISAPI Filters Health and Diagnostics HTTP logging Logging tools Request Monitor Tracing Security Basic Authentication Windows Authentication URL Authorization Request Filtering IP and Domain Restrictions Performance Static Content Compression Management Tools IIS Management Console IIS Management Scripts and Tools Management Service IIS 6 Management Compatibilty IIS 6 Metabase Compatibility IIS 6 WMI Compatibility IIS 6 Scripting Tools IIS 6 Management Console and yes to any additional prompts, then Click Next and Install and close when done. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted September 2, 2010 Report post Posted September 2, 2010 Step 6. Download, uncompress and Install vNext Now that SQL is ready we will install vNext itself, Browse to the unzipped files and double click on Splash.hta. Click on Install and answer Yes to the UAC prompt Click next when the Wizard appears As we want to decide where vNext is installed (and other options), Select Install a configuration manager primary server and click next Accept the License Terms choose to Check for updates and download newer versions to an alternative path (create the path first or it will complain) the updates are downloaded from the internet after the udpates are downloaded you'll get to choose the Site code, Site Name and installation folder as my site is a Primary and I've no Central Administration Site (CAS), I will choose the second option which is Primary Site Will be installed as a standalone site Choose Mixed Mode (native mode would require a PKI structure in place) Set your Database Server options (they are auto-populated) and the SMS Provider Settings next we select our Site System Roles and our Client Agent Selection (by default NAP is not selected) As this is still a beta, requeting your feedback is mandatory (no choice !) review the summary review the Pre-requisites check, if there are any errors (red) resolve them before continuing, we only have some warnings which we will resolve after the installation. Click on Begin Install when you are ready after some time, it will be complete, verify that all the sections are Green by scrolling down Click Finish and Restart your vNext server after the server has restarted, login and start the vNext admin console Congratulations, you are now using vNext !! Next > Using vNext in a LAB - Part 2. Configuration. Quote Share this post Link to post Share on other sites More sharing options...
Krumov Posted December 26, 2010 Report post Posted December 26, 2010 Maybe because the product is still into "Beta 1", it has issues discovering MS SQL server on a different machine. The MS SQL server, at this time, must be installed locally on the same machine as the MSSCCM v.Next. Also ensure you have the latest versions of the required dependences pre installed on the machine. Ivaylo Quote Share this post Link to post Share on other sites More sharing options...
brianleejackson Posted December 27, 2010 Report post Posted December 27, 2010 On 12/26/2010 at 8:46 PM, Krumov said: Maybe because the product is still into "Beta 1", it has issues discovering MS SQL server on a different machine. The MS SQL server, at this time, must be installed locally on the same machine as the MSSCCM v.Next. Also ensure you have the latest versions of the required dependences pre installed on the machine. Ivaylo Thanks for the tip Krumov. I am still testing it so everything is on one machine, so I hadn't run into this issue yet. Good to know. Quote Share this post Link to post Share on other sites More sharing options...
SaiTech Posted March 13, 2011 Report post Posted March 13, 2011 Hi,and thanks for the guide.. Does it matter what "SQL Server Collations" I set when I install SQL Server? /SaiTech Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted March 13, 2011 Report post Posted March 13, 2011 it might matter if you chose different settings on a different site server, unless you have a good reason i would stay with the default collation settings Quote Share this post Link to post Share on other sites More sharing options...
banxta Posted March 18, 2011 Report post Posted March 18, 2011 so if i am running a Windows Server2003 R2, i cant use this deployment procedure? just asking. regards Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted March 19, 2011 Report post Posted March 19, 2011 For what purpose? As this is still a BETA product... Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted March 20, 2011 Report post Posted March 20, 2011 as Peter says' it's a beta product so should only be used in a LAB environment to experiment with how the new version will look like, do not implement this version of ConfigMgr in a Production Environment, Microsoft does do carefully agreed upon TAP releases, if you have a customer that is interested in trialling beta software then speak to your Microsoft TAM Quote Share this post Link to post Share on other sites More sharing options...
Rajsekhar Posted March 29, 2011 Report post Posted March 29, 2011 I am currently installing and configuring the Beta 2 on my lab and I must thank you for the guidence that you have provided in this blog. I have read that Beta2 would support non-windows mobile devices (android, iphone, synbian)management. is that true? Do you have any documents or post regaridng the same ? thanks in advance, Raj Quote Share this post Link to post Share on other sites More sharing options...
