skinnyzaz
OSD at remote site
I setup a distribution point for a remote site. It has all the required packages needed for the task sequence but for some reason it is only using some of the packages from the local distribution site and coming back to our main office to get the other half of them. Both sites the main and the remote distribution are protected DP's and they are in separate subnets.
Anyone have any idea why this would happen?
7 answers to this question
can you try again and post the resulting smsts.log file ?
I just attached the file i hope that is correct. When I ran it again this time it grabbed the image only from the distribution point and grabbed all the software packages from the main site.
smsts.log
I figured out what I did wrong....... I had the boundary for the remote site included in my list for the main site. Now that I have removed that boundary from the main site all seems to be working fine. Thx anyways for the fast replies I really appreciate it. I love this website!
