I have recently trying to learn how to complete reports based on ADR Rules for Windows Updates as well as Office Updates. I run it against a ADR for a specific date (patch tues) against All System.
I am running one Called Software Updates  - A Compliance.   When i do so the report comes bac with 3 states Compliant - Compliance state unknown and Non-Compliant.  Just trying to understand what these mean with regards to if the clients have received the required updates.
Trying to figure out the difference between the 3:  Does the following mean
Compliant -  They received all of the updates required?
Compliance State Unknown - Don't know the status at this time if updates have been installed?
Non-Compliant - Never received the updates?
Trying to figure at what compliant really means?
Thanks for you help...
Craig
T
Compliant = The SU has been installed correctly.
Non-Compliant = the SU is needed and not installed or not rebooted to complete the install.
Compliance State Unknown = The SU scan results have not occurred and therefore the status is unknown.
