keywan
SCCM 2403 and MDT and UDI Issue
feel free to try it and report back here if it works, it looks like Microsoft is not testing MDT at all with ConfigMgr any more sadly
I have checked on the
C:\Program Files (x86)\Microsoft Configuration Manager\AdminConsole\XmlStorage\Extensions\Forms
and change the HTTP to HTTPS, it seems to work and you can create a TS with MDT
<?xml version="1.0" encoding="utf-8"?>
<SmsFormData FormatVersion="1.0" xmlns="https://schemas.microsoft.com/SystemsManagementServer/2005/03/ConsoleFramework">
  <Form Id="{ef095b1c-2087-4369-bf8a-57986ba313c9}" CustomData="SCCM_CreateBootImage" FormType="CustomDialog" >
    <Assembly Name="Microsoft.BDD.CM12Actions.dll" Namespace="Microsoft.BDD.Actions" ClassType="WizardDispatch" />
  </Form>
</SmsFormData>
try it, it works. But I am really not sure if the changing has any effected on the whole SCCM server settings or options
the smsts.log1.txt is the log file before I changed the HTTP to HTTPS
Please remember, I am using my TS with UDI designer. My TS did works successful with the SCCM 2207, after upgrade to 2403 does not work anymore
smsts.log1.txtFetching info...
the smsts24052024.log.txt is the log file after I changed from HTTP to HTTPS. After changing the HTTP to HTTPS I have created again a new MDT TS and new MDT Toolkit Package and run my TS, gain the same error message.
smsts24052024.log.txtFetching info...
here's the error
<![LOG[C:\_SMSTaskSequence\Packages\DIG006E0\Scripts\ZTISCCM.wsf(2, 11) Windows Script Host: The value for the attribute is not valid : language]LOG]!><time="07:22:59.382-120" date="05-24-2024" component="InstallSoftware" context="" type="3" thread="1820" file="runcommandline.cpp:77">
<![LOG[]LOG]!><time="07:22:59.382-120" date="05-24-2024" component="InstallSoftware" context="" type="3" thread="1820" file="runcommandline.cpp:77">
<![LOG[Command line is being logged ('OSDDoNotLogCommand' is not set to 'True')]LOG]!><time="07:22:59.382-120" date="05-24-2024" component="InstallSoftware" context="" type="2" thread="1820" file="runcommandline.cpp:478">
<![LOG[Command line cscript.exe Scripts\ZTISCCM.wsf returned 1]
so if you can determine why it's complaining about that you might be able to continue
