wmmayms
Guide: Adding drivers to a custom winPE (3.0)
Here are the command needed to add drivers to a custom WIM
1. Make sure you have Windows Automated Installation Kit installed (make sure you have the latest version)
2. Open "Deployment Tools Command Prompt" (Start -> All programs -> right click on Microsoft Windows AIK, choose Run As administrator)
3. Copy base files to c:\winpe (change x86 to amd64 for 64bit)
copype x86 c:\winpe
4. Mount imagefile
Dism /mount-wim /wimfile:c:\winpe\winpe.wim /index:1 /mountdir:c:\winpe\mount
5. Copy all drivers into a catalog for example c:\temp
6. Inject custom drivers
Dism /image:C:\winpe\mount /Add-Driver /driver:C:\temp /recurse
7. Look what drivers are installed
Dism /image:C:\winpe\mount /get-drivers
8. Save the changes
Dism /Unmount-Wim /MountDir:C:\winpe\mount /Commit
9. Change format from Windows Image format so we can boot from the file
copy c:\winpe\winpe.wim c:\winpe\iso\sources\boot.wim
And that is it!
You can now use this file (c:\winpe\iso\sources\boot.wim) in SCCM or burn it to a ISO (look at this post for info on that)
Cheers!
Edited by anyweb
added right click on Microsoft Windows AIK, choose Run As administrator
4 answers to this question
Whats the difference between using dism to inject drivers into your boot image and using the options within SCCM to add drivers?
If you right click a boot image within sccm (2012 sp1) go to properties, there is a drivers tab with a starburst to add a driver.
Do these effectively do the same thing?
Thanks for any clarity you can provide.
-Matlock
