wmmayms Posted August 16, 2010 Report post Posted August 16, 2010 Did anybody try this? I know its not officially supported yet.. Just wanted know if there are any major combability issues before i set up a new lab based on this. Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted August 16, 2010 Report post Posted August 16, 2010 i havnt tried it yet, so please tell us how it goes, Quote Share this post Link to post Share on other sites More sharing options...
0 wmmayms Posted August 18, 2010 Report post Posted August 18, 2010 Seems this is working just fine. Havent found any strange issues yet. Atleast not with the SQL 2008 r2 (had some problems with webdav, but that I blame on win 2008 r2, IIS would not save my settings to the xml conf file..atleast not on the first ocasion) Setup: Server1 Win 2008 r2 IIS 7 SCCM 2007 SP2 WSUS 3 SP2 WDS WAIK MDT Server2 Win 2008 r2 IIS 7 SQL 2008 r2 The server is only default installed at this moment...but so fare so good. Will tell you guys if i find any errors when i start adding roles and actually doing stuff Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted August 18, 2010 Report post Posted August 18, 2010 did you have to change any perms on the xml file ? Quote Share this post Link to post Share on other sites More sharing options...
0 wmmayms Posted August 18, 2010 Report post Posted August 18, 2010 On 8/18/2010 at 11:50 AM, anyweb said: did you have to change any perms on the xml file ? No just changed all settings back to the orignal state. Pressed save. Then i changed back again. Pressed save. After this MP was able to install withour issues. These where the ones i had problems with: Quote Share this post Link to post Share on other sites More sharing options...
