paddy Posted August 17, 2010 Report post Posted August 17, 2010 Hi there, when I look in my all systems collection I notice there are a number of machines still showing up with with Site Code: (blank), Client: No, Approved: No and Assigned: No I have tried pushing out the client again but still nothing happening to these machines. Any advice would be great. 1 Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted August 17, 2010 Report post Posted August 17, 2010 Take a look at the ccm.log Quote Share this post Link to post Share on other sites More sharing options...
paddy Posted August 17, 2010 Report post Posted August 17, 2010 Hi Peter, Sorry I am new enough to this product where is this log located.Also is this log on the server or client?? also what am I looking for in this log when I do locate it?? Thanks Quote Share this post Link to post Share on other sites More sharing options...
Eswar Koneti Posted August 17, 2010 Report post Posted August 17, 2010 On 8/17/2010 at 3:01 PM, paddy said: Hi Peter, Sorry I am new enough to this product where is this log located.Also is this log on the server or client?? also what am I looking for in this log when I do locate it?? Thanks You can take a look at SCCM server installaton folder let say d:\system center configuration manager\logs\ccm.log which will gives you information about the client push installation status.For more info about SCCM site server and client logs look at here Did you check the boundaries on your site sever ? also check the client push installation account rights which should have admin rights on the local computer to do this acitvity. 1 Quote Share this post Link to post Share on other sites More sharing options...
paddy Posted August 18, 2010 Report post Posted August 18, 2010 On 8/17/2010 at 3:07 PM, konetie said: You can take a look at SCCM server installaton folder let say d:\system center configuration manager\logs\ccm.log which will gives you information about the client push installation status.For more info about SCCM site server and client logs look at here Did you check the boundaries on your site sever ? also check the client push installation account rights which should have admin rights on the local computer to do this acitvity. The boudaries all look fine and also the client push Installation account has admin rights. I have tried running the client manually from the share and have attached the ccmsetup.log of this machine. Copy of ccmsetup.logFetching info... 1 Quote Share this post Link to post Share on other sites More sharing options...
Eswar Koneti Posted August 18, 2010 Report post Posted August 18, 2010 On 8/18/2010 at 10:21 AM, paddy said: The boudaries all look fine and also the client push Installation account has admin rights. I have tried running the client manually from the share and have attached the ccmsetup.log of this machine. Are you running the SCCM client on windows XP SP1 ? the minimum prerequisiste for SCCM client to be supported on WinXP SP2 recommended .For more info look at here Quote Share this post Link to post Share on other sites More sharing options...
paddy Posted August 18, 2010 Report post Posted August 18, 2010 On 8/18/2010 at 10:32 AM, konetie said: Are you running the SCCM client on windows XP SP1 ? the minimum prerequisiste for SCCM client to be supported on WinXP SP2 recommended .For more info look at here No all XP clients should be SP2. I have attached the ccm.log ccm.zipFetching info... Quote Share this post Link to post Share on other sites More sharing options...
Eswar Koneti Posted August 18, 2010 Report post Posted August 18, 2010 On 8/18/2010 at 10:45 AM, paddy said: No all XP clients should be SP2. I have attached the ccm.log The log clealy says ,The account which you have specified doesnt have admin rights to access admin$ share.ensure the client installation account has full permissions on the taregt computer ---> Attempting to connect to administrative share '\\10.4.102.41\admin$' using account 'ccc_dom\sms_install' and failing. Quote Share this post Link to post Share on other sites More sharing options...
paddy Posted August 18, 2010 Report post Posted August 18, 2010 On 8/18/2010 at 11:59 AM, konetie said: The log clealy says ,The account which you have specified doesnt have admin rights to access admin$ share.ensure the client installation account has full permissions on the taregt computer ---> Attempting to connect to administrative share '\\10.4.102.41\admin$' using account 'ccc_dom\sms_install' and failing. I am aware of this but this account has been granted full Domain admin access on the network. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted August 18, 2010 Report post Posted August 18, 2010 Can you connect to the admin$? Do you have a Restricted Groups GPO to delete local admins? Quote Share this post Link to post Share on other sites More sharing options...
