MaWi Posted September 16, 2010 Report post Posted September 16, 2010 Hi, I'm looking for a way to create a Task Sequence that wil partition/format the c-partition but leaves the d-drive intact during OSD. Does anyone have an idea how to do this? Greetings, Mario Quote Share this post Link to post Share on other sites More sharing options...
0 Eswar Koneti Posted September 16, 2010 Report post Posted September 16, 2010 On 9/16/2010 at 10:30 AM, MaWi said: Hi, I'm looking for a way to create a Task Sequence that wil partition/format the c-partition but leaves the d-drive intact during OSD. Does anyone have an idea how to do this? Greetings, Mario In task sequnce,remove partition disk task and select the operating system to apply on which drive with options under apply operating system task Quote Share this post Link to post Share on other sites More sharing options...
0 MaWi Posted September 17, 2010 Report post Posted September 17, 2010 On 9/16/2010 at 12:54 PM, konetie said: In task sequnce,remove partition disk task and select the operating system to apply on which drive with options under apply operating system task Ok, thanks!! I will try this today. Kind regards, Mario Quote Share this post Link to post Share on other sites More sharing options...
0 MaWi Posted September 17, 2010 Report post Posted September 17, 2010 Ok, it works!! Thanks Quote Share this post Link to post Share on other sites More sharing options...
Greetings,
Mario
