I tried to deploy software to a collection.It worked on some computers,worked after some time on other computers after updating DP.However on few computers i get the below message.However other packges got installed on those machines.The problem was one of the DP was ruuning out of space and two other DP's are not in production of the total DP' s attached to this package.Even the two retired ones do not have the package copied.It says ' Installed Pending' dated two months ago.My understanding is that the package cannot find the DP.When i updated the DP's after removing the packages from the one that was less on disk space the software got installed on one of the machines.However i still get the below message for some of the machines in the collection
"Possible cause: The content for this program must be downloaded into the computer's cache, or the content could not be located.
Solution: If the program is being downloaded, no action is required. The program will start once the download has been successfully completed. If the content can not be located, ensure that a distribution point with this content is available for this computer. Distribution point availability can be affected by roaming boundary configuration which is used to determine whether distribution points are classified as local or remote, or by enabling distribution points as protected distribution points. Distribution point availability can also be affected if you are using branch distribution points and the advertisement is configured with the option Run program from distribution point instead of Download content from distribution point and run locally. This is because branch distribution points do not support advertisements that are configured to run directly from a distribution point"
