DizzleSizzle
Adobe Flash issues
Hello, i am deploying Adobe Flash player 10.1.X using the MSI version. Everything deploys and works fine. The problem i am running into is that whenever there is a update for flash users are being prompted to update their flash player but since they are not Admins they can't. Is there anyway to disable auto updates of flash? is there any other way to do it rather than creating a mms.cfg file and adding the 0 for Autoupdate. I was looking for a reg key change which i can send out via GPO. Adobe Reader and acrobat are easy because you can use the Adobe Customization Wizard and create MST's to disable all of that but flash wont work for that tool. Any help would be great. Thanks.
