NoDowt
How to correctly install Right Click Tools
Hi All,
Just wondering if anybody can give me some pointers on correctly installing the right click tools from - http://myitforum.com/cs2/blogs/rhouchins/
I've just downloaded from there today & installed, but a bit unsure what options I should be selecting during the setup... e.g. Central vs Primary vs Workstation & When asked for Site and server details...
Sofar, I have selected Workstation (as thats where I am installing it... Do i need to install on Central & Primary servers also?), and have entered details for my 'local' SCCM site server... But I'm wondering I should have entered details for the Central site server instead...
Thanks!
Hi All,
Just wondering if anybody can give me some pointers on correctly installing the right click tools from - http://myitforum.com...logs/rhouchins/
Thanks!
If you are installing on workstation to connect to SCCM console,you can select workstation option and you will have to provide the Site and server details. Do you see a folder called sccm tools in C:\windows\system32.
You can verify this by opening the console and right click on computer for console actions.
