2ez24get
Setting Hostname before Applying Operating System
I have a working Online Windows 7 OSD with the Unknown Computers Collection in SCCM 2007 SP2. I want to make a Offline USB deployment. I want a script to prompt for a Hostname before the Applying Operating System in the TS. If someone can post step by step procedure. I tried the MDT computername.vbs but it did not work. Do I need to add a TS Variables?
Thanks.
3 answers to this question
Not sure if this will help, but this is what i use for unknown computer support and works like a charm.
http://blogs.catapultsystems.com/javery/archive/2009/01/23/have-os-deployment-ask-for-a-computer-name.aspx
I do have a VBS script in a package and run it from the TS via a run command line like the tech article say's to do. I have tried the following script computername.vbs from MDT 2010 and it fails to run in the task sequence. I get an error that the oEnvironment variable has not been defined.
Option Explicit
Dim numCount
Dim strComputerName
Dim objOSD
Dim mname
strComputerName = InputBox ("Please enter a name for the new computer:" ,"New Computer Name",mname,10,10)
if strComputerName = "" Then
Wscript.Echo "You must enter a computer name."
Else
oEnvironment.Item("OSDNEWMACHINENAME") = strComputerName
oEnvironment.Item("OSDCOMPUTERNAME") = strComputerName
End If
