DANC Posted November 1, 2010 Report post Posted November 1, 2010 Can anyone help me out with this. I'm trying to perform a simple install and capture of Windows 7 but keep getting the following errors Thanks Dan Trace.bmpFetching info... Quote Share this post Link to post Share on other sites More sharing options...
0 Eswar Koneti Posted November 1, 2010 Report post Posted November 1, 2010 On 11/1/2010 at 1:24 PM, DANC said: Can anyone help me out with this. I'm trying to perform a simple install and capture of Windows 7 but keep getting the following errors Thanks Dan This could be because of PAckage (MS10004)which is not avilable in DP ? Are you using Any drivers action(auto apply drivers ) ? or any product key in Task sequence ? or problem with your sccm client package ? Quote Share this post Link to post Share on other sites More sharing options...
Dan
