marine87
XP to 7 using Hardlinks - Not restoring the hardlink data
Hello everyone, I'm new here but am finding the info very useful. I'm fairly new to SCCM but do use it regularly for imaging machines. I have been given the task of finding a way to upgrade our current XP machines to 7 and preserving the user data, such as documents, pictures, desktop items, etc. I'm using one of the task sequence's I found on this site and have tried it out on an XP machine, and I see that it does copy user data and then it will reboot and install 7, but when I check to see if the user files are on the computer, they are no where to be found...It seems I'm just missing the piece to restore the data and/or is there something you have to do to the image to make it skip the part of the hd that is being used for the backup files? I'm not sure what info you need, but I'll be happy to supply any that I can to get this working. Thanks in advance for your help.
  On 11/27/2010 at 2:04 PM, Peter van der Woude said:
My guess is that you made a little mistake (like a typ-o) in one of the steps or in one of the bat-files. This could easily cause an Incorrect function -error.
Hi Peter, thanks for the reply, but sorry for the delay in getting back to you...I was out of town all last week. I've attached some screen shots to see what is typed in...I'm not seeing anything odd and the batch file, I just copy/pasted it...here it is:
Do you see anything that I may be overlooking? Any other suggestions? Thanks again, i really appreciate it.
Here is another part of the log file..It seems to fail at the do x86 scanstate One other question, I'm using the x86 files like in the example but we are using the 64bit version of 7...does that matter since its still on the XP 32bit side of things at this point?
<![LOG[Released the resolved source C:\_SMSTaskSequence\Packages\SSC0014A]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="InstallSoftware" context="" type="1" thread="1428" file="resolvesource.cpp:3471">
<![LOG[Process completed with exit code 1]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="commandline.cpp:1102">
<![LOG[!--------------------------------------------------------------------------------------------!]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="instruction.cxx:3010">
<![LOG[Failed to run the action: do X86 scanstate.
Incorrect function. (Error: 00000001; Source: Windows)]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="3" thread="1128" file="instruction.cxx:3101">
<![LOG[sending status message . . .]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:292">
<![LOG[send a task execution status message SMS_TSExecution_ActionFailError]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:314">
<![LOG[MP server TWSCCM1.totalwine.com and port 80. SSL=false. CRL=false.]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:458">
<![LOG[site code: SSC]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:489">
<![LOG[Client machine name: CJ-BCKGM81]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:494">
<![LOG[Client Identity: GUID:3BF6289C-CA5A-444E-B6A5-0DFD84EF02AA]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:496">
<![LOG[Advertisement ID: SSC200BF]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:505">
<![LOG[Package ID: SSC0014B]LOG]!><time="12:19:35.515+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="utility.cxx:507">
<![LOG[sending StatusMessage]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="libsmsmessaging.cpp:3806">
<![LOG[Formatted header:]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="libsmsmessaging.cpp:1500">
<![LOG[<Msg SchemaVersion="1.1" ReplyCompression="zlib"><ID/><SourceID>f0cf396b-4c7c-4fe3-a581-639129013b41</SourceID><SourceHost/><TargetAddress>mp:[http]MP_StatusManager</TargetAddress><ReplyTo>direct:OSD</ReplyTo><Priority>3</Priority><Timeout>3600</Timeout><SentTime>2010-12-06T17:19:35Z</SentTime><Protocol>http</Protocol><Body Type="ByteRange" Offset="0" Length="4168"/><Hooks/><Payload Type="inline"/><TargetHost/><TargetEndpoint>StatusReceiver</TargetEndpoint><ReplyMode>Sync</ReplyMode><CorrelationID/></Msg>
]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="libsmsmessaging.cpp:1501">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: TWSCCM1.totalwine.com:80 CCM_POST /ccm_system/request]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="1" thread="1128" file="libsmsmessaging.cpp:7446">
<![LOG[The request has succeeded. 200 OK]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="0" thread="1128" file="libsmsmessaging.cpp:7734">
<![LOG[set a global environment variable _SMSTSLastActionRetCode=1]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="0" thread="1128" file="executionenv.cxx:668">
<![LOG[set a global environment variable _SMSTSLastActionSucceeded=false]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="0" thread="1128" file="executionenv.cxx:668">
<![LOG[Clear local default environment]LOG]!><time="12:19:35.547+300" date="12-06-2010" component="TSManager" context="" type="0" thread="1128" file="executionenv.cxx:807">
<![LOG[Let the parent group (Run) decides whether to continue execution]LOG]!><time="12:19:35.562+300" date="12-06-2010" component="TSManager" context="" type="0" thread="1128" file="instruction.cxx:3210">
<![LOG[Let the parent group (Offline Scanstate in WinPE) decide whether to continue execution]LOG]!><time="12:19:35.562+300" date="12-06-2010" component="TSManager" context="" type="0" thread="1128" file="instruction.cxx:2461">
<![LOG[The execution of the group (Offline Scanstate in WinPE) has failed and the execution has been aborted. An action failed.Operation aborted (Error: 80004004; Source: Windows)]LOG]!><time="12:19:35.562+300" date="12-06-2010" component="TSManager" context="" type="3" thread="1128" file="instruction.cxx:2424">
<![LOG[Failed to run the last action: do X86 scanstate. Execution of task sequence failed.
Incorrect function. (Error: 00000001; Source: Windows)]LOG]!><time="12:19:35.562+300" date="12-06-2010" component="TSManager" context="" type="3" thread="1128" file="engine.cxx:214">
