Since the end of last week I have got a problem with distributing Software with the SCCM. I am using a package which I have distributed many times before and it has never been a problem. Now I made a new advertisement. According to the SCCM the package is received by about 200 Clients (thats ok) but the installation doesn't start on any of them. So I connected to some of the Clients to have a look at the logs but first I looked at the C:\Windows\SysWOW64\CCM\Cache folder to check if the package was really there. And to my surprise it wasn't though the SCCM reported that it has been downloaded by the Clients.
Afterwards I tried the same on a virtual testmachine. Same problem. So I decided to redeploy Windows 7 on the machine. Everything worked fine except for the fact that the software packages were not deployed. I updated the collection membership (as I have done many times before the redeployment) and got a second testmachine in the SCCM. One obsolate and one working. I deleted the obsolate one and since then the software deployment on the testmachine is working again.
The problem now is that the SCCM somehow thinks that all the clients have received the packages which just isn't true because I saw that there are no packages on the Clients. So it looks like the Computer Objects in my Collections are somehow damaged or just not working like they should. I can connect to the Clients via rightclick - start - remote desktop client; the windows 7 deployment is working as I saw when I tested it with the testmachine but the software distribution is not working.
I' am sure that the software distribution would work again if I redeployed all the clients again which I don't want to do because there has to be an easier solution for this problem.
Does anybody know how to fix this problem?
Thanks in advance
Bane
