SamayCSA
How to capture a Non Syspreped Machine using SCCM
Hello All-
I am running SCCM R2 and MDT on the same server. I was wondering if anyone knew how to capture a "non syspreped" image using SCCM. I have tried using SCCM custom task sequence and giving it only "Capture Operating System Image" step but it fails. I have also tried using the "Build and Capture" task sequence and removing the "Build" steps but it also fails.
Any help is appreciated.
