Thorsten
Prestaging with MDT 2010U1
4 answers to this question
ConfigMgr R3 prestaged media is the recommended method. MDT has a pre/post OEM task sequence, however even the MDT guys recommend that you use R3 prestaged media as it works the correct way.
Here is a walkthrough on R3 prestaged media:
http://myitforum.com/cs2/blogs/cnackers/archive/2010/12/11/configuration-manager-r3-prestaged-media-setup-and-walkthrough.aspx
You can use any task sequence you want to finalize the machine(s) provided it has the appropriate configuration as show in the guide i linked.
