Trung Thanh
Problem with Client Install SCCM 2007 R3
Dear all,
I installed SCCM 2007 R3 on Windows Server 2008 R2, extended Scheme domain. I push install Client agent on SCCM 2007 R3, Windows Server 2008 R2 (other server) is installed correctly, but Windows XP (32 bit) is not installed. I ran ccmsetup.exe but nothing appears on Task Manager, and no log appears on ccmsetup in Windows\system32\ccmsetup (windows XP).
All windows xp are up-to-date.
Please help me,
Regard,
5 answers to this question
I think your problem is not push this hotfix ( Password: -H+o2DaIt Password Changes On: 12/17/2010 Next Password: WR7lgQ]K_x) for XP SP3 Client.
I spent this issue when i try SCCM R3 :). For Good, I think you should reinstall your system, You can control what do you do :).
Good luck.
Hello all,
I have a similiar issue just installed SCCM 2007 r3. I'm trying to install the client to a windows 7 pro machine. It looks like it is pushing but not installing. When i go to C:\windows\system32\ccmsetup\ccmsetup.exe i click it the uia comes up and nothing happens. I've also gone to \\server IP and clicked on the sms_24c (24c = install name) clicked on client and tried to install it there as well. Below is a .log, please help if you can! Thanks for you time.
<![LOG[GetAdaptersAddressess entry point is supported.]LOG]!><time="09:23:08.508+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmiputil.cpp:118">
<![LOG[DhcpGetOriginalSubnetMask entry point is supported.]LOG]!><time="09:23:08.508+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmiputil.cpp:181">
<![LOG[Current AD site of machine is HOBO-Eagle]LOG]!><time="09:23:08.508+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="lsad.cpp:457">
<![LOG[Attempting to query AD for assigned site code]LOG]!><time="09:23:08.508+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="lsad.cpp:1766">
<![LOG[Executing query (&(ObjectCategory=MSSMSRoamingBoundaryRange)(|(&(MSSMSRangedIPLow<=167903238)(MSSMSRangedIPHigh>=167903238))))]LOG]!><time="09:23:08.523+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="lsad.cpp:1801">
<![LOG[Executing query (&(ObjectCategory=mSSMSSite)(|(mSSMSRoamingBoundaries=10.2.0.0)(mSSMSRoamingBoundaries=HOBO-Eagle)))]LOG]!><time="09:23:08.523+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="lsad.cpp:1862">
<![LOG[LSGetAssignedSiteFromAD : Trying to Assign to the Site <24C>]LOG]!><time="09:23:08.555+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="lsad.cpp:1922">
<![LOG[The MP name retrieved is 'HOBOEDC.EDCMAD.LOCAL' with version '6487l' and capabilities '<Capabilities SchemaVersion=1.0">
</Capabilities&gt]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="lsad.cpp:2869">
<![LOG[Retrieving client operational settings from AD.]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="lsad.cpp:4931">
<![LOG[ClientOperationalSettings search filter is '(&(ObjectCategory=mSSMSManagementPoint)(mSSMSDefaultMP=TRUE)(mSSMSSiteCode=24C))']LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="lsad.cpp:4673">
<![LOG[Command line: "\\10.2.0.10\sms_24c\Client\ccmsetup.exe" ]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4102">
<![LOG[CCMHTTPPORT: 80]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:8008">
<![LOG[CCMHTTPSPORT: 443]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:8023">
<![LOG[CCMHTTPSSTATE: 0]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:8041">
<![LOG[CCMHTTPSCERTNAME: ]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:8069">
<![LOG[FSP: ]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:8084">
<![LOG[CCMFIRSTCERT: 0]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:8126">
<![LOG[Config file: ]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4497">
<![LOG[Retry time: 10 minute(s)]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4498">
<![LOG[MSI log file: ]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4499">
<![LOG[MSI properties: SMSSITECODE=24C SMSCACHESIZE=8000 CCMHTTPPORT=80" CCMHTTPSPORT="443" CCMHTTPSSTATE="0" CCMFIRSTCERT="0]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4500">
<![LOG[source List:]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4508">
<![LOG[MPs:]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4527">
<![LOG[ HOBOEDC.EDCMAD.LOCAL]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:4542">
<![LOG[updated security on object C:\Windows\system32\ccmsetup\.]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8849">
<![LOG[A Fallback Status Point has not been specified. Message with STATEID='100' will not be sent.]LOG]!><time="09:23:08.570+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:9330">
<![LOG[successfully deleted existing ccmsetup.exe]LOG]!><time="09:23:09.584+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:3301">
<![LOG[Downloading file \\10.2.0.10\sms_24c\Client\ccmsetup.exe]LOG]!><time="09:23:09.584+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:5162">
<![LOG[Downloading \\10.2.0.10\sms_24c\Client\ccmsetup.exe to C:\Windows\system32\ccmsetup\ccmsetup.exe]LOG]!><time="09:23:09.584+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:5259">
<![LOG[File download 10% complete (61440 of 611168 bytes).]LOG]!><time="09:23:09.584+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 20% complete (122880 of 611168 bytes).]LOG]!><time="09:23:09.600+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 30% complete (184320 of 611168 bytes).]LOG]!><time="09:23:09.615+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 40% complete (245760 of 611168 bytes).]LOG]!><time="09:23:09.662+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 50% complete (307200 of 611168 bytes).]LOG]!><time="09:23:09.662+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 60% complete (368640 of 611168 bytes).]LOG]!><time="09:23:09.662+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 70% complete (430080 of 611168 bytes).]LOG]!><time="09:23:09.662+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 80% complete (491520 of 611168 bytes).]LOG]!><time="09:23:09.709+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 90% complete (552960 of 611168 bytes).]LOG]!><time="09:23:09.709+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[File download 100% complete (611168 of 611168 bytes).]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="0" thread="996" file="ccmsetup.cpp:8694">
<![LOG[Download complete.]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:5337">
<![LOG[Running as user "lrsadmin"]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:2690">
<![LOG[Detected 136963 MB free disk space on system drive.]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:463">
<![LOG[DetectWindowsEmbeddedFBWF() Detecting OS Version]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:509">
<![LOG[Client OS Version is 6.1, Service Pack Version 0]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:533">
<![LOG[Client OS is not a supported Windows Embedded Platform]LOG]!><time="09:23:09.756+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:535">
<![LOG[successfully ran BITS check.]LOG]!><time="09:23:09.818+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:7105">
<![LOG[isFileMicrosoftTrusted Verified file 'C:\Windows\system32\ccmsetup\ccmsetup.cab' is MS signed.]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:1207">
<![LOG[successfully extracted manifest file C:\Windows\system32\ccmsetup\ccmsetup.xml from file C:\Windows\system32\ccmsetup\ccmsetup.cab.]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:7233">
<![LOG[Loading manifest file: C:\Windows\system32\ccmsetup\ccmsetup.xml]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="manifest.cpp:93">
<![LOG[successfully loaded ccmsetup manifest file.]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="manifest.cpp:105">
<![LOG[Failed to correctly receive a WEBDAV HTTP request.]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="3" thread="996" file="ccmsetup.cpp:6225">
<![LOG[Failed to successfully complete HTTP request. (StatusCode at WinHttpQueryHeaders: 405)]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="3" thread="996" file="ccmsetup.cpp:6226">
<![LOG[A Fallback Status Point has not been specified. Message with STATEID='301' will not be sent.]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:9330">
<![LOG[Deleted file C:\Windows\system32\ccmsetup\ccmsetup.cab]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:9069">
<![LOG[Deleted file C:\Windows\system32\ccmsetup\ccmsetup.xml]LOG]!><time="09:23:09.849+360" date="01-04-2011" component="ccmsetup" context="" type="1" thread="996" file="ccmsetup.cpp:9069">
