Mr.G
SCCM Troubles - R3 installation not working...
Anyweb...can you give me some pointers on how to do that please as the console properties on hosts is reporting .2000 as is the hosts control panel CM application.
G
Probably,you can check that by looking at execmgr.log from ccm logs ?
take a look at this post, does it give you some ideas ? could be that the update worked and your still looking at old data,
have you verified the client version ON a client (not from the server)
Ok so I cleared the logs on 1 station. Here is the log execmgr.log content
<![LOG[Policy is updated for Program: *, Package: PCS00009, Advert: PCS20010]LOG]!><time="11:22:52.684+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3288" file="execreqmgr.cpp:6711">
<![LOG[On policy activation ignore disabled policy KB977384 - Advanced Client Patch Install]LOG]!><time="11:22:52.715+000" date="01-18-2011" component="execmgr" context="" type="2" thread="2976" file="execreqmgr.cpp:7160">
<![LOG[Mandatory execution requested for program KB977384 - Advanced Client Patch Install and advertisement PCS20013]LOG]!><time="11:22:52.715+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3920" file="execreqmgr.cpp:3317">
<![LOG[Creating mandatory request for advert PCS20013, program KB977384 - Advanced Client Patch Install, package PCS00009]LOG]!><time="11:22:52.777+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3920" file="execreqmgr.cpp:3440">
<![LOG[Policy arrived for parent package PCS00009 program KB977384 - Advanced Client Patch Install]LOG]!><time="11:22:52.840+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2912" file="execreqmgr.cpp:6456">
<![LOG[Raising event:
[sMS_CodePage(850), SMS_LocaleID(2057)]
instance of SoftDistProgramOfferReceivedEvent
AdvertisementId = "PCS20013";
ClientID = "GUID:10708593-EEAD-4FB0-A221-70854FD75A7B";
DateTime = "20110118112252.855000+000";
MachineName = "LIB-1";
ProcessID = 1488;
SiteCode = "PCS";
ThreadID = 2912;
]LOG]!><time="11:22:52.855+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2912" file="event.cpp:525">
<![LOG[Program KB977384 - Advanced Client Patch Install change to state WAITING_ENABLED]LOG]!><time="11:22:52.980+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3920" file="executionrequest.cpp:4685">
<![LOG[Execution Request for package PCS00009 program KB977384 - Advanced Client Patch Install state change from NotExist to WaitingDisabled]LOG]!><time="11:22:52.980+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3920" file="executionrequest.cpp:488">
Waited a fair while now and I did specify to run as soon as possible in the distribute software wizard.
I've not yet sent anything to this host, I wanted to make sure that .2157 was working first. That was my primary concern.
G
Refreshed log from host.
<![LOG[The user has logged off.]LOG]!><time="12:09:49.397+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2920" file="execreqmgr.cpp:4761">
<![LOG[Policy deleted for advertisement PCS20013 package PCS00009 program KB977384 - Advanced Client Patch Install]LOG]!><time="12:16:57.613+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3084" file="execreqmgr.cpp:6524">
<![LOG[Policy was deleted or expired for program KB977384 - Advanced Client Patch Install. Remove the execution request.]LOG]!><time="12:16:57.644+000" date="01-18-2011" component="execmgr" context="" type="1" thread="3084" file="executionrequest.cpp:4510">
<![LOG[On policy activation ignore disabled policy KB977384 - Advanced Client Patch Install]LOG]!><time="12:17:09.385+000" date="01-18-2011" component="execmgr" context="" type="2" thread="3668" file="execreqmgr.cpp:7160">
<![LOG[Mandatory execution requested for program KB977384 - Advanced Client Patch Install and advertisement PCS20014]LOG]!><time="12:17:09.385+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2176" file="execreqmgr.cpp:3317">
<![LOG[Creating mandatory request for advert PCS20014, program KB977384 - Advanced Client Patch Install, package PCS00009]LOG]!><time="12:17:09.385+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2176" file="execreqmgr.cpp:3440">
<![LOG[Program KB977384 - Advanced Client Patch Install change to state WAITING_ENABLED]LOG]!><time="12:17:09.400+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2176" file="executionrequest.cpp:4685">
<![LOG[Execution Request for package PCS00009 program KB977384 - Advanced Client Patch Install state change from NotExist to WaitingDisabled]LOG]!><time="12:17:09.400+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2176" file="executionrequest.cpp:488">
<![LOG[Policy arrived for parent package PCS00009 program KB977384 - Advanced Client Patch Install]LOG]!><time="12:17:09.400+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2820" file="execreqmgr.cpp:6456">
AdvertisementId = "PCS20014";
DateTime = "20110118121709.416000+000";
ProcessID = 176;
SiteCode = "PCS";
ThreadID = 2820;
]LOG]!><time="12:17:09.416+000" date="01-18-2011" component="execmgr" context="" type="1" thread="2820" file="event.cpp:525">
