I have created this .wim called MultiOs.Wim (3800 MB)
This has 4 OS in it
A) XP sp3 Sysprep sealed
XP sp3 Office 2007 Pdf reader Sysprep sealed
C) Win 2003 R2 Sysprep sealed
D) Win 2003 R2 Office 2007 Pdf reader Sysprep sealed
I was able to put four task sequences on a single DVD using MDT 2010 but now I am trying to use SCCM 2007 R2. I can put only single Task sequence on the stand alone DVD it seems.
I have now put four different "Apply OS sequence" in the same TS (each choosing different folder/section in the .wim) . Now is there an easy way where it will ask me a question like 1,2,3,4 and on that basis I can choose the OS that gets deployed?
This has 4 OS in it
My script is called getocode.vbs and is this
Dim Oscode
Oscode=1
Oscode = InputBox ("Please enter" & (Chr(13) & Chr(10)) & "1 for 2k3 r2 Plain" & (Chr(13) & Chr(10)) & "2 for XP plain" & (Chr(13) & Chr(10)) & "3 2k3 apps" & (Chr(13) & Chr(10)) & "4 xp sp3 office" , "Image code","1" , 30,30)
wscript.echo "OS code chosen was: " & Oscode
Where to keep this script? I am running it in a RUN COMMAND TS for now.
Documentation say to put it in
TSconfig.ini
[CustomHook]
CommandLine=”WScript.exe X:\getOscode.vbs”
But where does this ts.ini go?
