disstanda Posted February 14, 2011 Report post Posted February 14, 2011 Hi guys... I am searching some "REPLACEMENT" TASK SEQUENCE (wXP -> W7 / USMT / NEW HARDWARE REPLACEMENT).. Has anybody some tips / own EXPORT for me or tips how build steps in CUSTOM TASK SEQUENCE? Thanx a lot Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted February 14, 2011 Report post Posted February 14, 2011 here's how http://blogs.technet.com/b/mniehaus/archive/2010/07/20/mdt-2010-update-1-fixes-to-configmgr-state-migration-point-scenarios.aspx Quote Share this post Link to post Share on other sites More sharing options...
0 disstanda Posted February 15, 2011 Report post Posted February 15, 2011 anyweb: thanx. i created 2 TS. First (CAPTURE) should capture only and second will deploy OS and restore data. ok? But no data saved on server :-( I started in FULL OS (source pc), advertised CAPTURE TS, its runs, but ends without ERROR and on Distr. point i dont see any data(printscreens distriPo+distriPo2).. In attachments screenshots of my TS (capture for capture data from first pc and client for deploy os on new clear pc and restore data) and my SMSTSlog. Thank you very much for help.. this is my last scenario which i need start to works :-) smsts.log Quote Share this post Link to post Share on other sites More sharing options...
0 anyweb Posted February 15, 2011 Report post Posted February 15, 2011 hi did you create a Computer Association between source and destination pc's before capturing the data ? Quote Share this post Link to post Share on other sites More sharing options...
0 disstanda Posted February 15, 2011 Report post Posted February 15, 2011 anyweb: yes. here his screenshot. this was my idea: Restore01 is computer without OS, ready for deploy OS and RESTORE DATA from "LUKASSXPTEST8". I prepared for "Restore01" new collection called "RESTORE" and on end of "IMPORT COMPUTER INFORMATION" (from comp. association) wizzard targeted this new computer in this collection. On this RESTORE collection is targeted the CLIENT TS (for install OS and RESTORE DATA) thank you for your time Quote Share this post Link to post Share on other sites More sharing options...
0 disstanda Posted February 16, 2011 Report post Posted February 16, 2011 next details (hope helps) I used this steps (here from some another topic) 1. Create a task to Capture user settings in SCCM. 2. Create a collection for the capture of the source computer user settings 3. Advertise the task to the newly created collection from step 2 and make it available to boot media 4. Create a task sequence to build the machine and restore user settings in sccm 5. Create a collection for the restore/build of bare metal equipment 6. Advertise the task sequence to the Restore collection from step 5 and make it available to boot media 7. Import computer information from the bare metal machine in to computer association, and associate the Source and Destination computers 8. Add Source computer to the collection from Step 2 and boot using the boot media 9. Add Destination computer to collection from step 5 and boot using the boot media but troubles: 1) on source pc is some 20GB data and on server is only one 118MB MIG file 2) i have computer association (as you see in previous post), but on my destination collection (STEP5) is empty and i dont know ho import the new, clear computer.. its new pc without os / sccm client etc. Thank you Quote Share this post Link to post Share on other sites More sharing options...
0 disstanda Posted February 22, 2011 Report post Posted February 22, 2011 hi.. here is some my progress. my first trouble was in wrong "computer import" and association (reason was, that i had this station in sccm as "UNKNOWN"). Resolved deleting this "unknown" pc from sccm and import works fine. Now my "REPLACE" over SMP works fine (capture profiles from "documents and settings" and restore in "Users"), but my problem is, that no *.pdf, *.pdb and some next type of files capture (and restore of course). Is some way how set scan for "all files" or some current type files ? :-) Any idea what edit in capture? Thank you very much (i feel, that finish is near :-D :-D) here is my step in TS which i use for scan state: Quote Share this post Link to post Share on other sites More sharing options...
0 disstanda Posted February 22, 2011 Report post Posted February 22, 2011 What i found on internet, everything is in (configuration) xml files for USMT, true? So i need to create some mymigration.xml , but i cant fint any good example for my situation (collect de-facto all files from d:\ partition and everything from user profile) Thank you very much for examples of xml file and correct me if im wrong. Quote Share this post Link to post Share on other sites More sharing options...
0 Sharad-MCTS Posted April 3, 2011 Report post Posted April 3, 2011 Hi Could you please share the task sequence for download. Also I want to know can we do partition in Migration from Xp to 7 with SMP. If possible then please suggest Thanks Sharad Quote Share this post Link to post Share on other sites More sharing options...
Hi guys...
Thanx a lot
