SamayCSA
More than one task sequence on same media
Hello-
We are using SCCM 2007 R2 to deploy Windows Seven images to machines successfully.
In order to take the load off our PXE server, we have created Stand Alone Task Sequence Media either on a USB thumb drive or DVD for different images we have for the machines. The stand alone media works
What we are wanting to do, is to fit more than one Task Sequence (there are different task sequences to deploy different images, for example for KIOSK, Workstation, Cashier POS etc) on the same physical stand alone media (such as a 32 GB USB stick). Can you please tell us how we can do this ?
TIA
SamayCSA
2 answers to this question
you'd have to combine the logic of all three task sequences into one ts, and give the technician some choices in the beginning in order to start the right one, that can be achieved via MDT 2010 Update 1 udi or a front end HTA
the task sequence will then have groups inside it to detect what variable you set via the choices in your front end and take appropriate action
niall
