mighty82
HELP! "This installation package could not be opened."
i have a problem with install a setup.exe from the sccm to a windows 7 client 64bit.
i create a new package in sccm (sccm is update from sms 2003 to sccm 2007r3)
after the package i create the program and select the java.jre.6u20-32bit.exe
ok now i distribute the software package for all windows 7 64bit clients. (java 32bit version is run successfully if i download manually)
but from the dp (run advertised programs) i see follow error...
"This installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this is a valid windows installer package."
why i have this problem!!! if i download the same exe manually so its work on the same client!!! why not over the sccm!!
Plese help me.
see Attachment
Thanks!
9 answers to this question
  On 2/21/2011 at 10:22 AM, Eswar Koneti said:
can you look at execmgr.log ,CAS.log for errors ?
Check the version on DP and version on the client running ? Is it set to "Download and Execute" or "Run from Distribution Point"?
Try updating the package to DP and try to run it again .
DP Update i have maked now. but where is the log files?!?!
on the path sms\log i doesnt find the logfiles... (INFO I Updated from SMS 2003 to SCCM 2007R3)
I have actually the Problem...
it is a windows 7 problem?!?! security?!?! what ever....
The SCCM Advanced Client Version is the same. I Push the Client installation from the server to all clients.
Some another software runs perfectly.. but this java setup.exe not.. why!?
thx
  On 2/22/2011 at 4:46 AM, Eswar Koneti said:
logs can be found the SCCM client C:\windows\system32\ccm\logs on x86 and c:\windows\syswow64\ccm\logs on x64 .
what hapepns when you run the java setup.exe manually ? does it works then ?
yes its work if i start the same exe file from a local client...!!
i dont no why is not work when i distribute the package....
but if i start the same package on a xp client, there is work fine!
It is a Windows 7 Security?!?!
greetz
greetz
can you check if you have set the program to run only specific OS or on All OS types ?
can you post the program command line syntax?
Have you tried extracting the .MSI from the setup.exe file and using that instead?
1. Obtain the Offline Source file .EXE from http://www.java.com/en/download/manual.jsp.
(Don't forget to Unblock the downloaded .EXE files.)
2. Navigate to the logged in user's Application Data folder (for example: C:\Documents and Settings\JoeUser\Application Data or C:\Users\JoeUser\AppData\LocalLow).
3. Launch the downloaded .EXE installation file, but do NOT install the program (just leave it running at the initial installation window).
4. Copy ALL the files from the "...\Sun\Java\XXXX" folder containing the extracted contents of the downloaded .EXE file to another location.
5. Cancel the installation setup.
Yes i have extract the setup file and use the msi.
but why this error come...
Must i have change a special konfig or property on my windows 7 clients?!?! or on the sccm server....
thx for the reply
hi,
so now i have a new problem with deploy a application (only setup.exe) over the sccm.
we need to install the bizagi process modeler tool.
i download the setup.exe file. i create a new package and insert as program the setup.exe file.
after this i distribute the software to all windows workstations.
on the windows xp clients work fine but on the windows 7 prof client its not work.... :-(
see attachemend for the error
if i start manual the setup.exe file from the sccm its ok and i can install this.. but oder the sccm not..
why???
i have other problems with the java.jre.exe and now with the exe file from a another application...
should be check a specified config on the sccm to the windows 7 clients... or should be check a config from the windows 7 client to work better with sccm 2007...
please help....
thx
