Brett T
Weird problem using SCCM to copy files
I'm trying to use SCCM to run a batch file that amung a couple other things, copies some files from a network share to a specific folder on my workstations. I'm simply using a Task Sequence to run the batch file. The weird thing is that I see the batch file results in the client's smsts.log and it show that all commands ran correctly. It shows that 7 files were copied. But when I look on the workstation the files aren't there! I can't figure out why the smsts.log shows that everything was copied, but the files are nowhere to be found. Has anyone ever seen anything like this before or have an idea of what could be wrong? Thanks
Brett
