jrego
32 Bit XP to 64 Bit Win 7 in place with USMT
2 answers to this question
Use this. This is what we use. Just change the necessary references to your packages/boot images/ Operating System Images.
On the Restore User Files and Settings task be sure that it references a USMT package that has BOTH x86 and x64 files.
For the Do x86 Scan task be sure that it is referencing the right bat file. In my task i have the following:
cmd /c runscanstate-offlinewindir.bat %OSDStateStorePath% %systemdrive%
Lastly. Check all your logs. At what step is it failing? Look at the advertisement status and you should get an idea. Then look at the local logs on the machine if possible.
Hope this helps.
Joey
