thadkew
XP to Win7 hardlink problem
I downloaded the sample task sequence for an xp to win7 hardlink. To test, I used a freshly image xp box and created a slew of users (at least 3) both on and off the domain.
When I ran the win7 hardlink migration task sequence, NO accounts are migrated.
I watch the tk and it downloads what looks to be the proper files for the migration. And the task appears to be running the migration. But no accounts are put back on the new win7 installation.
I have only modified anyweb's sample to add the OS and put in some app installs that are necessary for our environment.
What could be wrong?
4 answers to this question
Is there anything back at all?? It sounds like it's not capturing/restoring at all...
On one test, an empty folder was created with a username. The second test had nothing.
Did you check the logs that should be created?
The logs point me to this:
2011-04-07 16:15:19, Info [0x000000] Startup exclusions - Adding excluded file pattern: C:\System Volume Information\* [*]
2011-04-07 16:15:19, Info [0x000000] Startup exclusions - Adding excluded file pattern: %SystemDrive%\^$UPGRADE.~OS\* [*] transformed to: C:\^$UPGRADE.~OS\* [*]
2011-04-07 16:15:19, Info [0x000000] Startup exclusions - Adding excluded file pattern: C:\^$UPGRADE.~OS\* [*]
2011-04-07 16:15:19, Info [0x000000] Startup exclusions - Adding excluded file pattern: C:\WINDOWS\Temp\tmp140.tmp\* [*]
2011-04-07 16:15:19, Info [0x080172] AgentManager: not loading agent CMockAgent in mockagent.dll due to configuration settings
2011-04-07 16:15:19, Info [0x080558] MXE Agent: Added XML script C:\_SMSTaskSequence\Packages\LKY0010C\x86\miguser.xml
2011-04-07 16:15:19, Error [0x08055b] MXE Agent: XML parse error while loading script C:\_SMSTaskSequence\Packages\LKY0010C\x86\migapp.xml. Message: hResult = 0x0, Line = 229, Position = 15; End tag 'rules' does not match the start tag 'migration'.
2011-04-07 16:15:19, Error [0x000000] EngineStartup caught exception: XmlException: hResult = 0x0, Line = 229, Position = 15; End tag 'rules' does not match the start tag 'migration'.
. void __thiscall UnBCL::XmlDocument::Load(class UnBCL::String *)
2011-04-07 16:15:19, Info [0x0803e6] Removing mapping for HKLM
2011-04-07 16:15:19, Info [0x0803e7] Successfully unmapped HKLM
2011-04-07 16:15:19, Info [0x0803e6] Removing mapping for HKU
2011-04-07 16:15:19, Info [0x0803e7] Successfully unmapped HKU
2011-04-07 16:15:19, Info [0x080487] Destroying OS analysis service
2011-04-07 16:15:19, Info [0x080488] Destroyed OS analysis service
2011-04-07 16:15:19, Info [0x000000] Leaving MigStartupOnline method
2011-04-07 16:15:19, Error [0x000000] Error while trying to start the migration process[gle=0x00000006]
2011-04-07 16:15:19, Info [0x000000] Failed.[gle=0x00000006]
2011-04-07 16:15:19, Info [0x000000] Migration failed because of an XML error; look in the log for specific details[gle=0x00000006]
2011-04-07 16:15:19, Info [0x000000] USMT Completed at 2011/04/07:16:15:19.984[gle=0x00000006]
2011-04-07 16:15:19, Info [0x000000] Entering MigShutdown method
2011-04-07 16:15:19, Info [0x000000] Leaving MigShutdown method
There's a line that is being parsed incorrectly, i guess. However, I haven't changed anything in the MigUser.XML file.
