User credentials are not required to access installation files. ccmsetup will be executed in service-only mode. ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
Updated security on object C:\Windows\system32\ccmsetup\. ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
A Fallback Status Point has not been specified. Message with STATEID='100' will not be sent. ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
ccmsetup service is stopped. ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
Successfully deleted the ccmsetup service ccmsetup 4/8/2011 9:35:11 AM 3052 (0x0BEC)
Ccmsetup is not registered in the Run key ccmsetup 4/8/2011 9:35:11 AM 3052 (0x0BEC)
Successfully deleted existing ccmsetup.exe ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
Downloading file C:\Windows\SoftwareDistribution\Download\Install\ccmsetup.exe ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
Downloading C:\Windows\SoftwareDistribution\Download\Install\ccmsetup.exe to C:\Windows\system32\ccmsetup\ccmsetup.exe ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
File download 42% complete (262144 of 611168 bytes). ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
File download 85% complete (524288 of 611168 bytes). ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
File download 100% complete (611168 of 611168 bytes). ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
Download complete. ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
Current directory is a not valid source location and no source was specified. Ccmsetup will attempt to auto find an MP source location. ccmsetup 4/8/2011 9:35:12 AM 3052 (0x0BEC)
Successfully created the ccmsetup service ccmsetup 4/8/2011 9:35:13 AM 3052 (0x0BEC)
==========[ ccmsetup started in process 3660 ]========== ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Version: 4.0.6487.2000 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Command line parameters for ccmsetup have been specified. No registry lookup for command line parameters is required. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Sending Fallback Status Point message, STATEID='100'. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
State message with TopicType 800 and TopicId {B2E46A2D-A2E2-4D41-9C09-8686CA10C228} has been sent to the FSP FSPStateMessage 4/8/2011 9:35:13 AM 3640 (0x0E38)
Sending Fallback Status Point message, STATEID='307'. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
State message with TopicType 800 and TopicId {E102D3BF-9584-46F6-AC1A-0EB088CD923D} has been sent to the FSP FSPStateMessage 4/8/2011 9:35:13 AM 3640 (0x0E38)
Failed to start the ccmsetup service (1053) ccmsetup 4/8/2011 9:35:13 AM 3052 (0x0BEC)
A Fallback Status Point has not been specified. Message with STATEID='301' will not be sent. ccmsetup 4/8/2011 9:35:13 AM 3052 (0x0BEC)
We just setup a new SCCM 2007 R3 server. The problem we are having is the client will not install using the software update point installation method.
If I do a client push install, it works. I should add, in our environment we cannot extend the schema. But our MP is published through WINS.
I will post the setup log below but it looks like the problem is the MP cannot be located. I don't why...
==========[ ccmsetup started in process 1448 ]========== ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
Version: 4.0.6487.2000 ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
Found additional ccmsetup.exe parameters through the registry. ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
Command line: C:\Windows\SoftwareDistribution\Download\Install\ccmsetup.exe SMSSLP=in-mdep-s3 SMSMP=in-mdep-s3 SMSSITECODE=MDP FSP=in-mdep-s3 ccmsetup 4/8/2011 9:35:06 AM 3052 (0x0BEC)
Command line: "C:\Windows\system32\ccmsetup\ccmsetup.exe" /runservice SMSSLP=in-mdep-s3 SMSMP=in-mdep-s3 SMSSITECODE=MDP FSP=in-mdep-s3 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
CCMHTTPPORT: 80 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
CCMHTTPSPORT: 443 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
CCMHTTPSSTATE: 2147483648 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
CCMHTTPSCERTNAME: ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
FSP: in-mdep-s3 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
No MP or source location has been explicitly specified. Trying to discover a valid content location... ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Current directory is not a valid source location. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Looking for an MP source through SLP... ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
GetAdaptersAddressess entry point is supported. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
DhcpGetOriginalSubnetMask entry point is supported. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Adapter {010769EB-2E59-44A6-BB82-2CF1D5590DAF} is DHCP enabled. Checking quarantine status. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Current AD site of machine is Default-First-Site-Name ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Attempting to query AD for assigned site code ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Executing query (&(ObjectCategory=MSSMSRoamingBoundaryRange)(|(&(MSSMSRangedIPLow<=2252649839)(MSSMSRangedIPHigh>=2252649839)))) ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Executing query (&(ObjectCategory=mSSMSSite)(|(mSSMSRoamingBoundaries=134.68.181.0)(mSSMSRoamingBoundaries=2001:18E8:0003:0181)(mSSMSRoamingBoundaries=2001:18E8:0003:0181)(mSSMSRoamingBoundaries=Default-First-Site-Name))) ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Couldn't find an MP source through SLP. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
No valid source or MP locations could be indentified to download content from.Ccmsetup.exe cannot continue. ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
Invalid ccmsetup command line: "C:\Windows\system32\ccmsetup\ccmsetup.exe" /runservice SMSSLP=in-mdep-s3 SMSMP=in-mdep-s3 SMSSITECODE=MDP FSP=in-mdep-s3 ccmsetup 4/8/2011 9:35:13 AM 3640 (0x0E38)
