thadkew
USMT Hardlink restore issue
My restore is not working now.
The capture part of the task sequence works, however the restore bombs and the items are still located in the _SMSTaskSequence\UserState\USMT folder.
I have manually tried to run the Loadstate command and get this:
Info [0x000000] loadstate C:\_SMSTaskSequence\UserState\USMT /q
Info [0x000000] 6.0.5860.5 (winmain(wmbla).061221-1313)
Warning [0x08040b] State data store failed calling CoInitializeEx in apartment-threaded mode. (hr = 0x80010106)
Warning [0x080262] GAC data store failed calling CoInitializeEx in apartment-threaded mode. (hr = 0x80010106)
Warning [0x08046d] No matching file list for OS version (object of class="class UnBCL::OperatingSystem" at {717108})
Warning [0x080467] CSysObjFilterFactory::CreateFilter: failed to init CListSysFileFilter
Warning [0x080000] CMigApp::Init - CReport::Initialize() failed.
Error [0x0802e3] SelectTransport: OpenDevice failed with Exception: class Mig::DeviceException: Win32ErrorException: Error(3), (NULL). Inner Exception: class UnBCL::DirectoryNotFoundException: \\?\C:\_SMSTaskSequence\UserState\USMT\USMT3\USMT3.MIG: path not found.
void __stdcall UnBCL::File::ThrowWinIOErr(long,const class UnBCL::String *)
void __thiscall Mig::CMediaManager::SelectTransport(unsigned int,struct Mig::IDeviceInitializationData *,int,int,int,__w64 unsigned long)
void __thiscall Mig::CIMGTransport::OpenDevice(struct Mig::IDeviceInitializationData *,int,int,int,int,__w64 unsigned long)
Error [0x08031c] SelectTransportInternal("LIB: Path(C:\_SMSTaskSequence\UserState\USMT\USMT3\USMT3.MIG)") caught exception = class Mig::DeviceException: Win32ErrorException: Error(3), (NULL). Inner Exception: class UnBCL::DirectoryNotFoundException: \\?\C:\_SMSTaskSequence\UserState\USMT\USMT3\USMT3.MIG: path not found.
enum MIGSTATUS __stdcall SelectTransportInternal(enum TransportID,struct Mig::IDeviceInitializationData *,int,int,int,__w64 unsigned long)
Error [0x000000] Unable to Select the IMG transport: MigSelectIMGTransport failed with MIGSTATUS 0x14.
Error [0x000000] Inconsistency detected: Store is not encrypted but user is supplied the key to decrypt.
Warning [0x0803db] IndirectKeyMapper: RegLoadKey(HKEY_USERS,S-1-5-21-138102894-3963109368-500872334-500,C:\Users\Administrator\NTUSER.DAT) failed; giving up (1223)
Error [0x0803b1] Cannot add mapping for user AT003873\Administrator. Error: 1223
Error [0x000000] Unable to start the migration engine successfully
Error [0x000000] USMT is unable to complete successfully.
Error [0x000000] Unable to restore the user state from the given location. The store may be invalid, you may have specified /decrypt for a store that is not encrypted, or you may not have specified /nocompress for an uncompressed store.
I don't know if this is the answer but it looks like it cannot find the compressed data store at the given path:
You might want to verify that USMT3.MIG is located where it is looking.
Hope this helps!
