Thebeats2009 Posted April 12, 2011 Report post Posted April 12, 2011 Hallo, Did we can integrate MDT with SCCM 2012?? Is that possible? Thanks Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted April 12, 2011 Report post Posted April 12, 2011 You can always use the scripts of MDT, but I don't think you can configure the integration. Main reason: totally different setup of the ConfigMgr Console. Quote Share this post Link to post Share on other sites More sharing options...
Thebeats2009 Posted April 13, 2011 Report post Posted April 13, 2011 You can always use the scripts of MDT, but I don't think you can configure the integration. Main reason: totally different setup of the ConfigMgr Console. Thanks Peter, This is right. I tried to configure the integration but that´s not possible. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted April 13, 2011 Report post Posted April 13, 2011 once MDT 2012 is released which should be sometime this year, we'll probably get the option to integrate Quote Share this post Link to post Share on other sites More sharing options...
alsterbrink Posted June 18, 2011 Report post Posted June 18, 2011 once MDT 2012 is released which should be sometime this year, we'll probably get the option to integrate Mdt 2012 is now avaliable on connect and intergrates fine into sccm 2012 beta 2. Brgrds Alsterbrink Quote Share this post Link to post Share on other sites More sharing options...
