Boedt Posted May 20, 2011 Report post Posted May 20, 2011 i got it to work with a new Server 2008 Standard R2 Thanks for your Help! Quote Share this post Link to post Share on other sites More sharing options...
Saiprasad Shetty Posted June 7, 2011 Report post Posted June 7, 2011 do i follow the step to delegate permission to the primary site server as well as CAS server. And is it fine i do that step since i missed it earlier after all the other steps are done. i.e i have installed both CAS and primary site. Quote Share this post Link to post Share on other sites More sharing options...
F1Online Posted June 23, 2011 Report post Posted June 23, 2011 thnx man got it up and running all's healthy and all components OK CLients all have the client tried myself to figure it out but after three attempts I found this guide which helped me to set it up correctly Quote Share this post Link to post Share on other sites More sharing options...
jayinoz Posted August 7, 2011 Report post Posted August 7, 2011 Thanks for this, one question CU14 (step 9) contains SQL Server 2008 All (Global) x64 sp1 2008_SP1_SapBI_CU14_2527187_10_00_2821_x64 2008 10.00.2821.00 1831032 5/9/2011 6:48:50 PM SQL Server 2008 All (Global) x64 sp1 2008_SP1_SNAC_CU14_2527187_10_00_2821_x64 2008 10.00.2821.00 7035874 5/9/2011 6:48:51 PM SQL Server 2008 All (Global) x64 sp1 SQLServer2008_SP1_CU14_2527187_10_00_2821_x64 2008 10.00.2821.00 264620376 5/9/2011 6:48:46 PM SQL Server 2008 All (Global) x64 sp1 2008_SP1_RBClckOnc_CU14_2527187_10_00_2821_x64 2008 10.00.2821.00 122209736 5/9/2011 6:48:47 PM SQL Server 2008 All (Global) x64 sp1 2008_SP1_RSShrPnt_CU14_2527187_10_00_2821_x64 Are all of these required? Thanks, Jay Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted August 7, 2011 Report post Posted August 7, 2011 I do not realy get your question... The only thing you have to do is to update the installed SQL Components with CU14. Quote Share this post Link to post Share on other sites More sharing options...
ramlan Posted August 7, 2011 Report post Posted August 7, 2011 Peter is right. I followed the guide to complete the install. Everything is working fine. I am running SQL 2008 SP1 CU14. This is the only one you have to install from CU 14 SQL Server 2008 All (Global) x64 sp1 SQLServer2008_SP1_CU14_2527187_10_00_2821_x64 2008 10.00.2821.00 264620376 5/9/2011 6:48:46 PM Quote Share this post Link to post Share on other sites More sharing options...
jayinoz Posted August 7, 2011 Report post Posted August 7, 2011 On 8/7/2011 at 11:00 AM, ramlan said: Peter is right. I followed the guide to complete the install. Everything is working fine. I am running SQL 2008 SP1 CU14. This is the only one you have to install from CU 14 SQL Server 2008 All (Global) x64 sp1 SQLServer2008_SP1_CU14_2527187_10_00_2821_x64 2008 10.00.2821.00 264620376 5/9/2011 6:48:46 PM Thanks Ramlan. Hi Peter - the question was, which one of the listed updates is required (the hotfix link provides in the post directed me towards the 5 listed files) - the answer, as provides by Ramlan Cheers, J Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted August 7, 2011 Report post Posted August 7, 2011 On 8/7/2011 at 3:45 PM, jayinoz said: Thanks Ramlan. Hi Peter - the question was, which one of the listed updates is required (the hotfix link provides in the post directed me towards the 5 listed files) - the answer, as provides by Ramlan Cheers, J i've updated the guide to make it clearer which download you need Quote Share this post Link to post Share on other sites More sharing options...
jayinoz Posted August 8, 2011 Report post Posted August 8, 2011 Thanks Anyweb, the most comprehensive gudei I've seen, and I'm optimistic this may actually get SCCM installed. I've one further question. The reason I'm installing SCCM 2012 is to use MS ForeFront 2012, and this I believe required WSUS Can I simply follow the guide here http://www.windows-noob.com/forums/index.php?/topic/485-how-to-install-wsus-3-0-sp1/ and istall WSUS 3SP2 on my SCCM server? Thanks, J Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted August 8, 2011 Report post Posted August 8, 2011 Yes you can just follow that link, as the requirements for WSUS are still the same. Quote Share this post Link to post Share on other sites More sharing options...
