Bumbi85
Problem with Build and Capture - SCCM 2007 SP2 Lab enviroment
Hi.
I have a problem with Build and Capture of Windows 7.
It goes threw the steps ok, until it comes to Prepare OS.
Then i get the following error: "sysprep.exe is not present on this machine"
The SCCM enviroment is uppgraded to SP2 recently.
the x64 boot image is taken from the OS CD.
And i have added the CD to the "Operating System Install Packages"
OS: Win 7 x64 Enterprise
I have check the install.wim file, and sysprep folder + content is present.
Log: sysprep.txt
Any ideas?
Haven't tried with a 32 bit-os, but the filestructure in windows catalog should be the same as the 64-bit os.
Tried with a 32-bit os now, and it works fine.
Have you guys had any problem with build and capture of a 64-bit Win7 in a vmware enviroment?
Forgot to mention that my test enviroment is on a vmware server.
Got a tips from about a possible solution: http://scug.be/blogs/sccm/archive/2010/02/03/sccm-deploying-windows-7-on-a-vmware-esx-environment-howto.aspx
