garcoli
SCCM PXE Issues
Hi ,
Wondering if I could get some assistance.
Background - I pretty much have all components on the one lab machine Windows Server 2008 R2, SQL 2008, MDT , WAIK, SCCM 2007 R2, DHCP, WDS , DNS etc.
Am connecting another machine via PXE to MDT and all is well machines will build OK.
When I follow your tutorial ( http://www.windows-noob.com/forums/index.php?/topic/667-deploy-windows-7/ ) adding the PXE roll to SCCM 2007 etc I am getting the following in the SMSPXE.log
ProcessDatabaseReply: No Advertisement found in Db for device smspxe 24/05/2011 17:57:59 5276 (0x149C)
I have attached the full log file. Is there any pointers you can give me. I know it is around computer association but I am follwoing your steps. Is there any other log files that i can check.
Many thankssmspxe.log
  On 5/24/2011 at 4:36 PM, Peter van der Woude said:
Did you add the machine to a collection? And did you advertise a task sequence to that collection?
Hi Peter,
Thanks for the reply - created a collection and assigned an advertisement to it. The I used computer association to ppulate the machine to the collection I created.
