Smytty
Stuck when trying to Run "Build and Capture" Task sequence for Win7
Hi Folks,
I am currently trying to do my first build and capture of a Win7 machine and I am running into some issues. My test machine boots into WinPE fine, I enter the password that I set, choose my task sequence and then I come to a screen that says "The task sequence cannot run because the files for T0100004 cannot be found on the distribution point". I am kind of confused because I have updated my DP with all of my packages. One thing that did catch my attention is that it is saying that is looking for T0100004 but when I look at the share on my server there isn't even a folder with that name so why would my task sequence be looking for a package by that name?
Also I went through the command prompt in WinPE and got the SMSTS.log file off of the machine. I have attacked a SS of that log, my smspxe.log and a capture of my task sequence.
Any help would be greatly appreciated as I am kind of under the gun right now to get this working or this project may be scrapped on me.
ok here is an update. I had a bright idea after I had left work yesterday, I was not sure if I had sent my SCCMClient package to my DP. I checked the package ID and lo and behold the package id was T0100004, the package that was causing it to error out before. So I copied me Client install package to my DP and now it works. The things that you come up with when you are nto even trying to think about it.
