I've upgraded my site to R3 and pushed out the hotfix for R3 to s small test group of users in our department successfully along with enabling power management on my site under site management/site settings/site systems/site-name
I am able to run pre-R3 reports but when i went through a tutorial to setup power management reporting, there is a further option under computer management/reporting/reporting services that I am missing and don't know how to add
My site does not have the redded-out server-name under the reporting services...nor is there an option to add the server.
My site does have R3 setup, the sql reporting service is running for my sccm2007 instance...
Is there some sort of sync i have to run with my sql server to be able to be able to see the server itself or does it require a configuration/import inside of sccm r3?
http://scug.be/cfs-file.ashx/__key/CommunityServer.Blogs.Components.WeblogFiles/sccm/image_5F00_0B5D1F54.png
