Johan
SCCM patch issue
Hi All
im new in SCCM and i've started to deploy patches to several workstation. I've created an update list for June's 2011 patch and deployed to all the testing workstation and servers. I want to see the patch status, to see whether the patches is installed or not and i select the Deployments that contain an update list which is under the Software Update - B. Deployment Management group.
But when i run the report, under Update for Microsoft Office 2007 System (as attached picture), it shows Required - 4 and Installed - 12....
Does this mean only 4 laptop is required to installed this patch? if so, why does it displayed Installed - 12? I dont quite understand....
