Pittyplatsch
Virtual machine deployment failed due compressed storage
My Hyper-V Cluster with 3 Nodes is managed by SCVMM. Two cluster shared volumes are available for the deployment. When I want to deploy a machine to the cluster shared volume2 following error appears:
'TemplateTest': Cannot open attachment 'C:\ClusterStorage\Volume3\TemplateTest\Server 2003 R2 Enterprise 64Bit NOT SYSPREP_disk_1.vhd'. Error: 'The requested operation could not be completed due to a virtual disk system limitation. Virtual disks are only supported on NTFS volumes and must be both uncompressed and unencrypted.' (0xC03A001A). (Virtual machine ID 88534423-1B24-43E6-AB6A-AA6B76871447)
It seems that the volume ist "compressd" but in the properties of the volume compression is unchecked (on all three nodes). New virtual machines are marked blue. See attachment
0 answers to this question
