shamos Posted July 12, 2011 Report post Posted July 12, 2011 Hi I follow all steps for installing SCCM vNext 2012 but i got this error in the end of installation. Setup cannot create the database , and when i checked the sql server I found the database and here is the error in log file 07-12-2011 08:36:04> Creating XML indexes on table CI_ConfigurationItems, column SDMPackageDigest <07-12-2011 08:36:04> Creating XML indexes on table CI_SDMPackageLocalizedData, column LocalizedData <07-12-2011 08:36:11> Imported CLR assembly ServiceBrokerInterface from file ServiceBrokerInterface.dll. <07-12-2011 08:36:12> Imported CLR assembly MessageHandlerService from file MessageHandlerService.dll. <07-12-2011 08:36:13> Imported CLR assembly DcmObjectModel_SQLCLR from file DcmObjectModel_SQLCLR.dll. <07-12-2011 08:36:14> ***SqlError: [42000][33009][Microsoft] [sql Server]The database owner SID recorded in the master database differs from the database owner SID recorded in database 'CM_S01'. You should correct this situation by resetting the owner of database 'CM_S01' using the ALTER AUTHORIZATION statement.<07-12-2011 08:36:14> Error: Could not create assembly CryptoUtility.<07-12-2011 08:36:14> Could not install CLR assemblies.[color=#FF0000][/color] Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted July 12, 2011 Report post Posted July 12, 2011 what version of sql server did you try ? Quote Share this post Link to post Share on other sites More sharing options...
shamos Posted July 12, 2011 Report post Posted July 12, 2011 Hi Anyweb Thanks for your fast response ,I sloved the problem it was because the user which I am using have different schema in CM_S01 and master DB . Thanks too much Quote Share this post Link to post Share on other sites More sharing options...
