mmvvpp Posted September 21, 2011 Report post Posted September 21, 2011 On 8/19/2011 at 3:19 AM, smallc said: Hi Guy I think the problems is the permission of System Management, you can try it again following the setup 1.Open the "Active Directory users and computers", find "system" folder. 2.open System properties on the system folder, then click security tab. 3.add the your sccm computer name. 4.click the advanced,find the your sccm name and edit it. 5.select "this object and all descendant objects" on apply . 6. then click ok. you can see this link: http://blogs.technet...e-shooting.aspx This is the chinese team of sccm, you can see it. my English is just so so,I wish you can know it clearly. My email & MSN : liuzheng@live.it Skype : liuzheng05121 Any no clear, please let me know. Thanks, that solved my problem Quote Share this post Link to post Share on other sites More sharing options...
