Mike S
Automated Diskpart Script using Boot Media
I have a semi-quick question. How can I implement an automated solution that executes the diskpart command before the TS begins?
We maintain quite a few enctrypted laptops in my organization. As a result, no deployments will run until we perform diskpart. I already have a correct script file in place that will automate the commands needed. What I would like is to automate the actual diskpart command. Currently, once I boot using a USB flash drive, I have to press F8 to get the command window, I then have to switch to the root of the flash drive and type diskpart /s diskpart.txt. I would like this process to be automatic once I boot using the flash drive. How can I do this?
Thanks,
Mike
I havent read through all the post.
But im guessing you are after something like this :-)
select volume 0
assign letter=d
select disk 1
online disk noerr
attributes disk clear readonly noerr
clean
create partition primary noerr
assign letter=e noerr
format FS=NTFS LABEL="Application Volume" QUICK noerr
select disk 2
online disk noerr
clean
assign letter=f noerr
format FS=NTFS LABEL="Database Volume" QUICK noerr
select disk 3
online disk noerr
clean
assign letter=g noerr
format FS=NTFS LABEL="Transaction Volume" QUICK noerr
select disk 4
online disk noerr
clean
assign letter=h noerr
format FS=NTFS LABEL="Bank Volume" QUICK noerr
exit
Commandline in task seq:
diskpart /s "%scriptroot%\Custom\DiskPartSCCM.txt
A solution inside the Task Sequence would be to use the format.com command from the x: drive. Since the format command is already in the ram (x:) drive it doesn't required to be copied to the encrypted partition, later if you prefer you can rerun diskpart.
Command line: FORMAT.com C: /V:System /FS:NTFS /X /Q /Y
Start in: x:\windows\system32
Hi how about some settings in you Boot image if you go to the Customisation tab (2012 1511) you can add the following command line
cmd /c xcopy.exe *.* X:\ /IERYH & cmd /c Diskpart /S X:\Disk-Part-Clean.txt
you will need to add the .txt file on a file share and include the path in the "include files for prestart command"
Expand
This helped me a lot, however I am stuck on one part. After Diskpart runs, I need to reboot or I get the same error. However, if it reboots after DiskPart runs, it will run the Diskpart script again  and it is stuck in a loop.  How can I tell it to reboot but not run the Prestart command again?
Expand
I don't get involved too much with our SCCM system but I am building a large number of machines and making my own build stick. I'm struggling to work out where I'd put the files that are mapped to X in the above. Would there be a file share mapped during the build process? Could I drop the Disk-Part.Clean.txt file on a folder on the build stick, or at this point in the process can the system not see those folders?
Usually we just drop a diskpart.cmd and the txt file on the build stick and press F8 to navigate to it and run it that way, but this obviously looks like a better option.
