liuyanshare
errors on install SCCM2012, need help.
I installed SCCM2012 Beta2 followed 'using vNext beta2 in a LAB - Part 1. Installation' here.
But when I finished the Step4, I checked log file in c:/ExtADSch
there are lots of errors there, I don't know why.I have the Domain administrator account and joined in the local administrator group in both DC and SCCM server, so I think it was not for the permission reason.
anybody can help? thank you!
here is the errors from c:/ExtADSch
<07-29-2011 12:04:30> Modifying Active Directory Schema - with SMS extensions.
<07-29-2011 12:04:30> DS Root:CN=Schema,CN=Configuration,DC=andeby,DC=local
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-Site-Code. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=mS-SMS-Assignment-Site-Code. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-Site-Boundaries. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-Roaming-Boundaries. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-Default-MP. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=mS-SMS-Device-Management-Point. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-MP-Name. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-MP-Address. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=mS-SMS-Health-State. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=mS-SMS-Source-Forest. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-Ranged-IP-Low. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=MS-SMS-Ranged-IP-High. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=mS-SMS-Version. Error code = 5.
<07-29-2011 12:04:30> Failed to create attribute cn=mS-SMS-Capabilities. Error code = 5.
<07-29-2011 12:04:30> Failed to create class cn=MS-SMS-Management-Point. Error code = 8202.
<07-29-2011 12:04:30> Failed to create class cn=MS-SMS-Server-Locator-Point. Error code = 8202.
<07-29-2011 12:04:30> Failed to create class cn=MS-SMS-Site. Error code = 8202.
<07-29-2011 12:04:30> Failed to create class cn=MS-SMS-Roaming-Boundary-Range. Error code = 8202.
<07-29-2011 12:04:30> Failed to extend the Active Directory schema. Your Windows NT logon ID does not have the necessary privileges to extend the Active Directory schema, please find details in "C:\ExtADSch.log".
is your account a member of Domain Administrators ? also double check that that account has Schema Admins listed in the Member Of tab
