infinity33594
SCCM 2007 client push issues
I am currently trying to push out the sccm slient to my winxp workstations. I have one domain and sccm sees them in the collections. when I look at the collection in the client column it shows YES, it also shows approved, and in assigned it says Yes and No for blocked. When I try right click and install a client it fails everytime.
in Site settings>client Push installation properties I have checked the "Enable client push installation to assigned resources" and the box "Enable client push to site systems".
In the accounts tab I added an account with Domain Admin rights (domain\account) and checked the password. (I've triple checked to make sure the account has domain admin rights)
From a client I can manually connect to teh SCCM server \\servername\sccm_sitename and can manually install the sccm client with no errors
When I try to install it using the sccm client push it fails with the following output from the CCM.log file.
---> WNetAddConnection2 failed (LOGON32_LOGON_NEW_CREDENTIALS) using account burlington\sccadmin (00000035) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.351 2011 Eastern Daylight Time><thread=2984 (0xBA8)>
Submitted request successfully $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.382 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Getting a new request from queue "Retry" after 100 millisecond delay. $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.382 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Found CCR "HS-A009-20_BURLINGTON_ORG.BURLINGTON.CCR" in queue "Retry". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.382 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Received request: "HS-A009-20_BURLINGTON_ORG.BURLINGTON" for machine name: "HS-A009-20" on queue: "Retry". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.491 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Stored request "HS-A009-20_BURLINGTON_ORG.BURLINGTON", machine name "HS-A009-20", in queue "Processing". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.491 2011 Eastern Daylight Time><thread=3976 (0xF88)>
WARNING: High volume of CCRs. Slowing down the queue processing thread~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:35.491 2011 Eastern Daylight Time><thread=3976 (0xF88)>
---> WNetAddConnection2 failed (LOGON32_LOGON_NEW_CREDENTIALS) using account burlington\sccadmin (00000035) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:38.065 2011 Eastern Daylight Time><thread=6992 (0x1B50)>
---> WNetAddConnection2 failed (LOGON32_LOGON_NEW_CREDENTIALS) using account burlington\sccadmin (00000035) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:38.439 2011 Eastern Daylight Time><thread=4524 (0x11AC)>
---> LogonUser failed (LOGON32_LOGON_INTERACTIVE) using account burlington\sccadmin (0000052e) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> Attempting to connect to administrative share '\\192.168.109.213\admin$' using machine account.~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> Failed to get token for current process (5) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> ERROR: Failed to connect to the \\192.168.109.213\admin$ share using account 'Machine Account' $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> ERROR: Unable to access target machine for request: "FW-C128-03_BURLINGTON_ORG.BURLINGTON", machine name: "FW-C128-03", access denied or invalid network path. $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
Stored request "FW-C128-03_BURLINGTON_ORG.BURLINGTON", machine name "FW-C128-03", in queue "Retry". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
<======End request: "FW-C128-03_BURLINGTON_ORG.BURLINGTON", machine name: "FW-C128-03". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
======>Begin Processing request: "FW-C304-TE_BURLINGTON_ORG.BURLINGTON", machine name: "FW-C304-TE" $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> Trying each entry in the SMS Client Remote Installation account list~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> Attempting to connect to administrative share '\\FW-C304-TE.burlington.org\admin$' using account 'burlington\administrator'~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:43.946 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> WNetAddConnection2 failed (LOGON32_LOGON_NEW_CREDENTIALS) using account burlington\administrator (00000035) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:44.211 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> WNetAddConnection2 failed (LOGON32_LOGON_INTERACTIVE) using account burlington\administrator (00000035) $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:44.243 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> The device FW-C304-TE.burlington.org does not exist on the network. Giving up~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:44.243 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> Trying each entry in the SMS Client Remote Installation account list~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:44.243 2011 Eastern Daylight Time><thread=8512 (0x2140)>
---> Attempting to connect to administrative share '\\FW-C304-TE\admin$' using account 'burlington\administrator'~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:44.243 2011 Eastern Daylight Time><thread=8512 (0x2140)>
Submitted request successfully $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:45.506 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Getting a new request from queue "Retry" after 100 millisecond delay. $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:45.506 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Found CCR "HS-A013-02_BURLINGTON_ORG.BURLINGTON.CCR" in queue "Retry". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:45.506 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Received request: "HS-A013-02_BURLINGTON_ORG.BURLINGTON" for machine name: "HS-A013-02" on queue: "Retry". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:45.615 2011 Eastern Daylight Time><thread=3976 (0xF88)>
Stored request "HS-A013-02_BURLINGTON_ORG.BURLINGTON", machine name "HS-A013-02", in queue "Processing". $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:45.615 2011 Eastern Daylight Time><thread=3976 (0xF88)>
WARNING: High volume of CCRs. Slowing down the queue processing thread~ $$<SMS_CLIENT_CONFIG_MANAGER><Thu Aug 04 08:16:45.615 2011 Eastern Daylight Time><thread=3976 (0xF88)>
3 answers to this question
Are your A records in DNS correctly resolving to your clients? I'd suggest spot-checking a few. Also, did you define a client push installation account that has administrative remote access to your client systems?
By the way, you said that the "Client" column says "YES" -- this would mean the client is already installed, and does not need to be pushed. I'm a little confused why you're trying to push to existing clients.
Hope this helps.
Cheers,
Trevor Sullivan
http://trevorsullivan.net
http://twitter.com/pcgeek86
<p>
  On 8/4/2011 at 12:34 PM, Trevor Sullivan said:
</p>
<p>Are your A records in DNS correctly resolving to your clients? I'd suggest spot-checking a few. Also, did you define a client push installation account that has administrative remote access to your client systems?</p>
<p> </p>
<p>By the way, you said that the "Client" column says "YES" -- this would mean the client is already installed, and does not need to be pushed. I'm a little confused why you're trying to push to existing clients.</p>
<p> </p>
<p>Hope this helps.</p>
<p> </p>
<p>Cheers,</p>
<p><strong>Trevor Sullivan</strong></p>
<p><a class="bbc_url" href="http://trevorsullivan.net" rel="nofollow" title="">http://trevorsullivan.net</a></p>
<p><a class="bbc_url" href="http://twitter.com/pcgeek86" rel="nofollow" title="">http://twitter.com/pcgeek86</a></p>
<p>
</p>
<p> </p>
<p>Hi just wanting if anyone can tell me why most of my machines have the client installed and just a few in each of the collections don't have the client installed, also what does: </p>
<p>WARNING: High of CCRs. Slowing down the queue processing thread<span class="Apple-tab-span" style="white-space: pre; "> </span>SMS_CLIENT_CONFIG_MANAGER<span class="Apple-tab-span" style="white-space: pre; "> </span>26/03/2012 12:58:27 PM<span class="Apple-tab-span" style="white-space: pre; "> </span>7728 (0x1E30)</p>
<p> </p>
<p>Here is some of the listings in CCM.log that I am not understanding.</p>
<p> </p>
<p> </p>
<div>
<div><img src="webkit-fake-url://3DA5CC5D-55C3-4C72-89A2-1F315F92CA98/image.tiff" /></div>
<div> </div>
<div>Thanks in advance for any help on some of the above issues.</div>
</div>
